Questions on Pen Blanks
Tom Collins
>Greetings All, This is my first post here although I have been lurking for some time.
I scored a large red cedar trunk today and I would like to make some pens from it for the people who gave it to me.
Should I saw the blanks down to a certain dimension and let them air dry or can they be turned green? If I stabilize the blanks as mentioned in a previous post do they need to be dried first? Can the blanks be stabilized before drilling the hole or does that not work.
Sorry for all the ?'s. This kind of came up in a hurry and I've never made a pen before.
On a side note, I'm neighbors with Dave Peebles but I doubt if he will admit it.
Tom Collins
Re: Questions on Pen Blanks
Steve Kubien
Steve Kubien
>Others with far more knowledge will surely chime in but it is my understanding that turning pens with green wood is asking for trouble. The wood will shrink as it dries and since it won't likely crush the brass tube, it will split. Do not drill the blanks prior to drying either. You will have problems inserting the tubes later as the hole becomes oval or, worse, warped along its length. If it were me, I would mill the blanks (3/4" square and 6" long or so) and stack them log-cabin style. Depending on the weather in your area, they ought to be dry enough in a couple of months.
Good luck.
Steve Kubien
Ajax, Ontario
Stuart Johnson
>In the past I have cut blanks over sized, staked them to dry for a few months. If you are in a hurry use the microwave oven to dry them.In any event you don't want to turn them green.
eaglesc
>Agreed with all of the above.
If you want to turn a couple real fast(two days)
Cut some oversized about an inch square.
Nuke at 1/2 power for 45 secs and remove from the microwave immediately.
Let cool for an hour and repeat.
To check moisture content I weigh them before and after nuking.
When the weight doesn't change I turn them.
You can do this process 15-20 times over a weekend and be turning them sunday nite.
Anotehr method to check moisture is to put them in a plastic bag while nuking.
If no condensation appears onthe bag you are good to go.
