Joining dust collector pipes
Lynn from Port Townsend
>About a month ago I stumbled on a site that had a program one could run online that printed out the cuts you need to make to join two pipes of the same or different diameters together at a specified angle and offset. I thought that I had bookmarked the site, but I can't find it now.
Can someone point me back to that site?
Thanks.
Re: Joining dust collector pipes
Re: Joining dust collector pipes *LINK*
Bill McWhirter
>Hope that this is what you were looking for. Worked well for me except that I used PVC cement to join the pipes. I stuck the template to the pipe with 3-M spray adhesive and used a scroll saw to make the cuts.
Pipe Joint Template Online Software Manual
>Thank you. This is the link I was looking for. Lynn
eaglesc
>Sheet metal workers do it all the time in the field and don't need a program.
Whack it off with a miter saw(I use tin snips on galvanized),place it on the duct you are stubbing into and trace around with a marker.
cut inside the line.
Use mastik tape.
What did we do before computers?
Think?
God forbid!
Dave Peebles Lyons, Ohio!
>Eagle,
I find that to be a surprising reponse in this forum.
I always thought that any question is ok to ask here.
Dave
Re: ??
eaglesc
>"Eagle,
Dave"
I don't undertand your response to my post.
I just replied there is a way to do something that is rather easy without the aid of a computer.
