Box Elder HF
Box Elder HF
Box Elder HF
Carole Valentine
>This stuff was punky, punky! I decided to try putting water based poly on it to stiffen it up for the finishing cuts, since I did not want to change the color. It worked great. No penetrating finish, just highly sanded and then buffed with white diamond and a little Renaissance wax.
Re: Box Elder HF
Re: Box Elder HF
>Really beautiful Carole.
Re: Box Elder HF
Re: Box Elder HF
Kevin Gerstenecker
>Carol, that is very pretty. Wonderful color, excellent form, and the grain orientation couldn't be presented better. REALLY NICE! Thanks for sharing!
Re: Box Elder HF
Re: Box Elder HF
Vince
>Carole,
You nailed that one!!!! The finish looks great and the form is right on !!
Vince
Re: Box Elder HF
Re: It's a cute wee bit of a thing!
Jamie Donaldson
Re: Box Elder HF
Beauty!!!
Gil Jones on Lake Seminole GA
Re: Box Elder HF
Oh that's just pretty!
Carol in Illinois
Re: Box Elder HF
Nice!!!!!!!!!
Barbara Gill, Remlik VA
>So glad you are back turning again.
Re: Box Elder HF
Re: Box Elder HF
Mark Paulley
>Carole,
WOW! That is super!! I really like how the red curves around with the form of the vessel.
Thanks!
Re: Box Elder HF
Re: Box Elder HF
Mark Paulley
>Carole,
I forgot to ask; What are the dimensions?
Thanks
Mark
Re: Box Elder HF
Re: Box Elder HF
Carole Valentine
>Thanks folks. Mark it is 4"x3".
Re: Box Elder HF
Mike Stafford
Re: Box Elder HF
Mike Stafford
>That is a pretty little thing, Carole. I love to see small pieces done well and this is an example of just that. Very nice in every way.
Re: Box Elder HF
Re: Box Elder HF
Dave Noon
>Lovely looking piece Carol. I'm just staring to play a bit with hollow forms. I have a ton (literally I think) of box elder to play with.
I find it is very nice to turn and cuts well but I always seem to have trouble with end grain tearout.
How do you typically deal with it?
Thanks,
Dave
Re: Box Elder HF
Re: Box Elder HF
Carole Valentine
>Hi Dave,
End grain can be a bear on Box Elder. The most I can tell you is be sure your tools are razor sharp and take light cuts. If you try to hog wood when you are cutting, the tear-out seems to pull fibers from very deep in the wood and the you have a real mess, or a "design opportunty" as some prefer to call it. The final series of cuts should be a very, very fine shear cut which produces thread-like curls - not dust. On this piece which was beyond optimum turning age, I used a light coat of waterbased poly, let it harden over night, then made my final shear cuts which removed the poly layer. I used the WB poly because I did not want to give the wood an amber color. I then sanded to 600 and bleached the piece. Final sanding went up to 12,000 micromesh since I used no applied finish other than a little wax. The biggest problem is the inside, but the same advice for sharp tools and light cuts applies.
Re: Box Elder HF
Re: Box Elder HF
George Van
>Hi Carol; just saw this and I am glad you posted it. As usual the form is �spot on�
I find it interesting your results with the water based poly, I will be forced to get a small can myself to give it a try. I have to wonder how deep the poly penetrated and if it was all cut away or if it is giving you some help in the final finishing also.
Re: Box Elder HF
Re: Box Elder HF
Carole Valentine
>Thanks, George. The poly was all cut/sanded away. If it hadn't been, I believe it would have interfered with the even penetration of the bleach solution.
Re: Box Elder HF
Re: Box Elder HF
Jennifer@Indy.USA
>Sweet as pie Carole. Love the color of this piece of BE. As always your form is dead on. Always a treat to veiw.
Jen :)
Re: Box Elder HF
Just perfect, Carole.
Don henthorn
>You sure didn't lose any ground during your rest from the lathe. Keep them coming, I love seeing your work.
