>Someone dropped a couple of logs off and neither of us knew what it was. He described the leaves as squat heart shaped without the point (not fan like Ginko) and said he recalled some sort of white flowers in the spring. When fresh cut, the heart wood is greenish brown, but turns reddish as it dries. The bark is grayish outside with red just underneath the first layer. No identifiable smell to me. I have looked and looked on the net and can't find anything like it or with the leaves and flowers he described.
>How about Red Bud. It usually has redish flowers, but the wood and bark look right. What little I have turned is rather stringy, but color is excellent. Tree also has seed pods like black locust.
>The sharp contrast between the sap and heart wood plus the greenish case almost certainly makes it redbud. In addition, the narley growth pattern on your two pieces and the leaf description almost confirm it.
It turns smooth but moves a lot if turned green. Drying in log form makes the chance of getting good stock less likly. Turn it greed and let it move...
>Thanks, guys. I believe it is redbud. I did a little research on it and there is white variety. Guess I will cut up the other log and seal it. Going to try piece green too.
>I also believe it is Red Bud Carole. The bark and wood color is a dead ringer for Red Bud that grows in our area. It turns fairly well, but it sure is hard when dry. You are correct in your research, there are native Red Buds that bloom white.
We have many hundreds of dogwood trees on our property, most of them pretty small. A neighbor gave me a dogwood tree big enough that I sawed some 1x12's from the center but a tree that large is rare (at least around here) since most die long before then, especially if they get too much sun. Straight trunks that grow tall and thin in the middle of the woods are a favorite for people who make rustic furniture and walking sticks, especially if it has grown "twisty" from honeysuckle vines. It makes wonderful firewood.
Dogwood is wonderful to turn. It is very hard and dense and turns smooth. Kids especially seem to like things made of dogwood, perhaps because of the name. The wood generally has a creamy light brown color but can range from bland to spectacular. The wood in the past was often used for mallets, wedges, tool handles, and mechanical parts on things like spinning wheels and looms (it gets smoother with wear). Green dogwood can almost split wide open while you watch - I've had 8" diameters get 1" splits in the side practically overnight. Blanks without pith removed and the ends sealed did well.
>Carole - if it looks like this in a few weeks it is definitely Redbud. Bark sure looks like it. A friend took one down last fall about 6" in diameter and I turned a piece and sealed the ends with wax emulsion. Stored in my garden shed over the winter so it wouldn't be too low for humidity and it cracked in every imaginable place. This picture is about actual size. I would get your hopes up. The main trunk in my wood pile has ahuge gaping crack in it now. They make up for this fault with their beauty in the spring!
