Finish for antler pen.
C.W.Stivison
>I need to make a pen for a friend out of deer antler. What kind of finish should I use. Thanks
CW
C.W.Stivison
CW
Re: Finish for antler pen.
eaglesc
>Hard to give an exact answer.
Putting a finish on a deer antler pen varies due to the condition of the antler.
If it is solid I polish with MM and then a thin coat or two of CA MMing between coats.
In many instances the antler has punky or porous sections.
In those cases I sand with CA using a slurry to fill in the voids.
I do this with the coarser grits using Klingspor gold cloth "sandpaper" the only sanding medium I use other than Micro mesh.
AS I progress through the grits I contiue to add CA .When I get to the MM I do not add Ca.
After going all the way though theMM I inspect the pen to see if any more CA is necessary.
There are many who use no finish at all.
Depending on the use the antler pen will get it may become stained.
A white antler pen that is handled with grimy paws can get nasty looking.
At a bare minimum put a carnauba on it but the material should be very sound with no porous sections.
If you have enough to practice on do so and save the best pieces for the final try.
Bear in mind the porosity on the antler will change along its' length.
If you have been lucky enough to get axis antler disregard all ot the above.
It is rarely porous.
Thanks CW
C.W.Stivison
Bruce Wiseman
>I don't know this for a fact, but I have been told that antler dust is very toxic. Please wear a mask when sanding that stuff.
keith zimmerman, Normal IL
>If solid, I sand to 12000 MM, then a few coats of thin CA.
keith
eaglesc
>Any dust isn't good for you.
ANtler is no worse than any organic mater in your lungs.
A DC boot near the lathe solves the problems.
Travis Northcutt
>Sand to 1500 grit and I use Hut PPP. While antler may not be toxic, it stinks something awful. A mask would help keep that smell out of your nose.
