Re: Working Both Ends
>Hi Keith,
This is my procedure (there are, certainly, others):
1. Center the full log with the centers' points at the pith points.
2. Reduce to log to the largest possible cylinder.
3. Decide which end will be the "top", true up that end, and cut a step to exactly the diameter of the faceplate you will use; larger is better here.
4. Remove from centers, trim the nubby, and mount the faceplate to that step you formed. The piece here was put on a 6" plate.
5. Remount the piece with the tailstock in use and cut the profile of the main body up to the start of the shoulder where it will neck in.
6. Hollow the main body form (use a steady if you have one) through a hole just big enough the pass your tool.
7. In equal steps cut the profile and hollow the shoulder area.
8. Reduce the diameter of the neck area.
9. Refine and finish-sand the body (this is "commitment time").
10. Remove from the lathe, remove the faceplate, and remount in a donut compression chuck (shopmade) that exposes the entire neck area plus some of the finished shoulder.
11. Drill a 1/2" hole down the center of the neck into the body-void.
12. Put the tailstock on and bring the center into that 1/2" hole (added stability).
13. Turn and finish the profile of the neck.
14. Remove the tailstock and hollow the nect out to a uniform thickness.
15. Sand the neck (inside and out) and dress the rim.
16. Plug the bottom hole with a slice of the same log to match the grain pattern.
17. Finish off the lathe
[breath!!!]
mm
