Hunter carbide tips- long
George Van
>Last Wednesday I was in Duluth, MN, with Mike Hunter and some friends to try some of Mike�s tools and prototypes out. We had a good time and everyone had a chance to try all the tools on different woods and at different settings. I used one in a Sudol bar on a 16� vase and was very impressed on the ease of removing a lot of wood in a hurry. When I returned I bought a 3/16� Hunter tip for my Trent Bosh tool and have been giving it a go on some junk pieces that have rot and cracks to see how they perform on questionable blanks. I am enjoying the Trent Bosch tool more than ever now that it has the new tip. It is more aggressive and therefore I have to be more careful and check thickness more often while I hollow, as I am removing more material than I did previously with less effort. The figured grain and the rot/solid areas seem to pose no problems for this cutter. One of the fellows said he uses his in root balls with good success. I also have a tip to try on my Rolly Munro tool, I am anxious to get a nut so I can give it a try also.
Below is one that made it, spalted maple crotch 6�x4.25. The neck was intended to be higher and smaller but the pith was so rotten I had to turn lower to get to somewhat good wood for a rim. I had one other that did not make it as I could not hold the cracks and rot together. The foot had to be this size as smaller or round would have been rot and I can already look through the bottom. Sorry, I still have problems getting enough light bounced to the front of the vase to eliminate shadowed areas.
Re: Hunter carbide tips- long
>I don't see anything wrong with the photo. It's very good as well as the piece. Good job on both.
Re: Amen Bro!
Jamie Donaldson
George Van
>Thanks John and Jammie, I appreciate your help and advice.
Crappy Wood?....
Wally Dickerman in Arizona
>George, life is too short to turn crappy wood.
Wally
Re: Crappy Wood?....
George Van
>I agree with you Wally buuuuttt�.. I have a hard time practicing on the nice stuff, but then when it works out I wish I had! I guess lesson learned.;-)
