Follow Up...Sanding Inside HF's.....
Wally Dickerman in Arizona
>Ron's post yesterday on using a rubber fingertip as an aid in sanding inside a hollow vessel was a good one. However, in my opinion Ron's method of gluing the sandpaper to the rubber tip is dangerous. I've been using rubber fingertips for sanding for many years...hundreds of hollow vessels. Because of a rough surface, a flaw in the wood, a crack, or whatever, I've had the first grit used snatched from the rubber tip upon contact with the wood. Had the sandpaper been glued to the rubber tip I could have had a serious injury to my finger.
My method is to use strips of sandpaper about an inch and half wide. I fold it over from each side so that there are three thicknesses of sandpaper with a grit side in contact with the rubber tip, which helps to keep it from slipping. This allows me to move and refold the sandpaper for a fresh grit. The rubber tip, plus three thicknesses of sandpaper helps to prevent heat. I don't have large fingers, but I use the extra large size. I want it to be a bit loose.
Sounds dangerous, sticking your finger through a small opening in a rapidly turning piece of wood, but I can't remember ever having had an injury.
Nobody but another turner sticks his finger inside a piece to see how smooth it is. If your finger is longer than mine you might feel where I haven't sanded.....
Wally
Re: Follow Up...Sanding Inside HF's.....
Norm Smith in Nova Scotia
>Wally, Thats what is so great about this site. The exchange of ideas by all, old and new turners.
Thank`s
Norm
Ron in Drums PA
>Thanks for your email Wally.
quote: "The rubber tip, plus three thicknesses of sandpaper helps to prevent heat."
As we all know, to much heat can cause problems. I'm not sure I understand this, so please correct me if I'm wrong.
Heat is generated by the friction of rubbing sandpaper over wood.
Isn't it true then that three layers of sandpaper is only padding your finger(s) from the heat and not preventing it?
Is it possible there is more heat at the point of friction before it is noticed because of the padding, or is the difference only minor and nothing to worry about?
>You're right Ron. I should have said that it helps to keep heat from making your finger uncomfortable. The lathe should be running at a speed that not too much heat is generated. For the same reason the sandpaper should be kept moving, as it should for any kind of sanding.
Wally
Dick Hines
Dick Hines
>I don't stick my finger inside of a turning piece of wood. I found some forcipesin a hardware store sold as clamps. I picked a stright and curved pair for only $8. If I can't reach where I need to sand it does not get done.
Anyone sticking thier finger in a hollow form and finding an unsanded area can do just sand the next one them selves.
Re:I always cringe when I hear.........
Jamie Donaldson
>... turners suggest the use of forceps to hold sandpaper for sanding the interior of a vessel thru a small opening. I have both seen and heard of cases where the wood grabbed the paper and the forceps, and the fingers thru the handle holes were severely injured, including cut completely off. If you insist on using this tool in this manner, never place your fingers thru the handle holes.
You're absolutely right, Jamie
GaryG in MD
>If forceps are used at all, the finget holes should be taped over with duct tape to absolutely prevent such use in a moment of thoughtlessness. ...Gary
Re: You're absolutely right, Jamie
George Van
>That's a good idea Gary, tape is going on mine this morning.
Dick Hines
Dick Hines
>Forgot about that. DON'T PUT FINGERS IN CLAMP HOLES!!!!
I figured if it was unsafe to stick fingers into a turning piece of wood that everyone would think not to stick their fingers into a the holes of a tool going into said turning wood.
Wilford Bickel
>My forceps are hanging on the wall on a small brad that is stuck through the blue painters tape that has the finger holes taped up. I realized one night my old brain could not remember to keep my fingers out of the holes it is so natural to put them there so the painters tape went on and I've never done it since!!
