turning fresh cut walnut
p f davies
>i noticed that only the center third of 6-7 inch diameter branch is the traditional dark walnut color, will turning a bowl from abranch like this be sucessful or will the white wood punk out and the project be useless? also who do i contaCT TO TRADE OR SELL THE 16 INCH DIAMETER LOG LEFT OVER FROM TOPPING OUT THIS TREE?
Re: turning fresh cut walnut
>pf
The dark is heart and the white is the sapwood. Both are fine to to. When I turn walnut, I usually try to have some white wood includeed for contrast and drama.
The 16" log you should keep to turn. There's so much walnut around right now that your log is worth very little. I've got sixc whole tree stacked and ready to mill one day soon.
mm
RPE
>PF.
It can be a little frustrating, but rewarding also. You need real sharp tools. The sapwood (white wood) will not cut or sand up like the heartwood (brown wood). The sap wood will dry faster and quicker than the heartwood. Two different textures. The sapwood will tend to get fuzzy during sanding and cutting. The heartwood will be just fine. The solution? Don't turn limb wood. Use trunk wood if at all possible. Or cut all the white wood away. You will be much happier with the result. The best thing to do is to rough turn the wood to about a one inch wall thickness and place it in a paper grocery sack staple it closed and date it and weigh it. When it stops losing weight, turn it again. It will turn up nice and you will be happy with the result. It should take about six months for the bowl to dry in the sack. You can leave some of the sapwood on if you allow it to dry, but if you turn it to final green, you will have problems with the sap wood.
RPE
Dinyar Chavda
>If you don't turn the heartwood and the sapwood, I think you'll miss out on a lot of possible creative opportunities. After Watching John Jordan's video, I deliberately started playing with positioning the sapwood. Some examples are:
and...........
Dinyar Chavda
Re: or...........
Dinyar Chavda
Ralph Watts
>PF
If the wood is fresh, you can turn a piece to completion then let it do its thing. The advantage of this is that the sapwood will remain white and you will get a good color contrast. If you let the wood dry or sit around for an extended period, the sap wood will turn a brownish grey. I don't know of any way to prevent this--except for turning green.
Roughed out pieces have a better chance of keeping the white than storing in log or blank form but even these pieces will loose the conrast after a while..
Regards, Ralph
ebd
ebd
>I've turned a lot of black walnut and I've not found this to be the case at all. I rough turn, bury in shavings till dry, and then finish turn. I've never seen the sapwood turn any color other than what it starts out as. Some pieces are more than a few years old so I imagine I would have seen it by now if it was going to happen.
Allen Neighbors
>I've got a 14" tall Vase that I turned from Walnut. It was in log form for 2 years in my woodpile, unprotected. The sapwood in it is brownish gray. It might have happened because of beginning spalt. It had a pretty bad inclusion in the rim that I had to tape to finish turning it. I filled that with crushed turquoise/epoxy.
I believe if I had turned it green there would have been a noticable difference. I don't remember ever turning green walnut, so I don't know what it is like, but I'd give it a shot... roughturning, soaking in soap, and drying in kiln then returning it.
Just my thoughts on it.
will sapwood turn very dark?
JKJ in East TN
>I hope this is somewhat related and not a hijack, but the comments about the sapwood changing reminded me of something I've meant to ask.
I've cut walnut with differing amounts of sapwood, but once I rescued a tree that had been bucked into long firewood lengths and left on the ground for an unknown time but enough for the bark to start deteriorating and come off easily.
There was NO visible light-colored sapwood anywhere - the wood was a uniform dark walnut color all the way from the pith to the bark. (I got many good bowl and spindle blanks from it.) The wood was not wormy and had no significant decay.
Could this have had sapwood that darkened or could it have been all heartwood with no sapwood?
Re: will sapwood turn very dark?
Brian Hahn in SW Wisconsin
>There was an article in one of the woodworking magazines a couple of years ago about this. Probably in FWW, but it might have been WOOD. There also was some discussion either here or on the main board about the article. If I remember correctly, heat will turn the sapwood dark. That's one of the reasons that lumber mills steam walnut as part of the drying process.
JKJ in East TN
>>...heat will turn the sapwood dark
They use steam to get the wood to about 160-180F without drying. The kiln people say cooler temperatures still work but take longer. (They say some customers specify no steam since steaming can weaken the color)
But the wood I picked up with zero light sapwood had been sitting in a pile along the side of the road and could not have gotten very hot. Will walnut sapwood still turn as dark as the heartwood over time? In reading the sawmill forums, some say it will (if kept wet, if let on the ground, etc.) and some say it won't. Perhaps it depends on the specific tree, time of year it is cut, or something else.
Ron in Drums PA
>Normally no.
Steaming walnut before kiln drying will darken the sap wood at the expensive (IMO) of discoloring the heartwood. The wood will still be dark brown but it loses something that is not easy to explain without seeing it in person. JMO
