Sanding inside of hollow forms tip *Pics*
Ron in Drums PA
All I do is CA glue some sandpaper to the tip and sand away.
Ron in Drums PA
Re: Sanding inside of hollow forms tip *Pics*
Norm Smith in Nova Scotia
>Ron, great idea. Thank`s
Carole Valentine
>Good idea Ron. Not sure where I would find these around here - an office supply store or a drug store, hopefully.
>Office supply stores carry them They are called Finger cotts.
Mark Kauder, Phenix City, AL
>Sure would beat CA glueing sandpaper right on your finger. ;)
and probably much safer than using a latex glove.
Mark
Wally Dickerman in Arizona
>Been using these for years. I'm wondering why you glue the sandpaper to the tip. I just triple fold a small piece of sandpaper and quickly go from one grit to the next. Triple folding puts sp grit against the rubber and helps to keep it from slipping. Works great.
Wally
Ron in Drums PA
>Wally:
"I'm wondering why you glue the sandpaper to the tip"
� The tips are cheap.
� When I tri-fold the sand paper, it seems to slip a bit. This way I always know where the sand paper is.
� If I lift my finger a bit, the paper stays with me
I use 5 with different grits, 100, 150, 250, 320 and 400. When the paper gets dull I just rip off the paper and CA glue fresh paper. I started doing this over a year ago and I'm still using the 5 tips that I started with.
Carole:
I bought them at a Staples, I think I paid a buck or 2 for a box of 12
adrien
>Not sure John, but those tips appear to be considerably stronger than the thin latex finger cots which I don't think one could pull a glued piece of sandpaper off of. (Don't end a sentence with a preposition.)
Carole Valentine
>They are. I just went and got some (same kind) I have not tried them yet but I am wondering if you don't have to use more than one layer of sandpaper because of the bumpies on the finger thingie. Will let you know.
Ron in Drums PA
>All I use is one layer, it works.
>Triple fold it. Then you can quickly bring up fresh grit. Triple folding it also helps control heat.
Wally
George Van
>Thanks for the tip Ron, it is very timely as my interest in hollow forms increases!
