>I just rough turned an awsome sycamore bowl (sorry, camera is broken) but it has a streak through it which is just on the punky side. Any ideas to beef up this section. I haven't had too much trouble so far, but I have not started the final cut.
>Hi John, depending on your final finish I've used thinned down lacquer to firm up the wood. It dries fast and you can cut a-little and add more as needed. Good luck.
>John I use lacquer thinned 50/50 with lacquer thinner. I brush or pour some on, let is soak in and then pour more on. I let it dry and do a test cut. If it doesn't cut well I put more on. sometimes it takes quite a bit and it will take a good while to dry but it hardens up nicely. The downside is, not all finishes will work with it but many will. I use lacquer as a finish so it works great with that.
If it's not terribly punky and your just getting tearout, coat it with a layer of Johnson's paste wax and try a cut. Sometimes one or two coatings and passes with a really sharp tool are all it takes.
I'm dying to try wally's technique but just haven't had the right piece of wood yet.
If you're interested in a commercial, water-based product, "PC-Petrifier" works well. It's not overly expensive at $8/pint (a lot cheaper than CA glue!). You can get it at a number of brick&mortar stores or online. It works nicely on spalted wood that has gone a little over the edge.
Two things: Like thinned lacquer, you can also use thinned oil-based polyurethane to strengthen the area. I use the mineral spirits that I clean my poly brushes in. Like John Lucas suggested, it may create issues with whatever your finish will be.
You can also use thinned shellac. If you use the dewaxed version, you can put any finish over it.
>I've had wonderful success using the tung oil sealer that is sold by Lee Valley. I poured it into several rough-turned bowls in which the Minwax/wood hardener products didn't work nor did a 50/50 solution of white glue and water. I poured a goodly amount of it into the roughed-out bowls and let it soak in and dry for several days before doing the final turning. The resulting appearance was worth the effort (and the expense of the stuff).
>I'm currently working on piece of punky box elder and don't want it to darken. I wondered if anyone had tried the WB poly. I will after dinner. I never had much luck with the 50/50 white glue process.
>Carol, ultra blond shellac in a 1# cut will help strengthen punky areas and leave the wood quite natural. I do however get better results if necessary with thinned Deft, which is like the old airplane glue.
>Thanks, George. I use those on other woods but I have not had much luck with shellac or lacquer not imparting a slight amber tone on very light woods.
