Re: Jamison system limitations
Lyle Jamieson
>Thanks for your question so I can clarify.
Refer to the Packard catalog. Number 105805 Page 16 is the bent swivel assembly I referred to. The photo has the cutter in the wrong side, but thats another thread. It fits into my boring bars to reach around corners and get into smaller holes that are not much bigger than the boring bar itself. I have them for sale (are there rules I should not solicit here??)from me direct and you have the option of getting a new bent assembly or just the 3/8 bent shaft and exchange the swivel assembly from your straight swivel holder. All parts are interchangeable. Call me to place an order. 231-947-2348
I have made, for my own use, smaller boring bars to get into small items like Christmas ornaments. But they are too expensive to manufacture for production and sale to others. I find the supported system still works the best because I have fingertip control and the laser to get thin uniform walls. You can get some made for yourself as cheap as I can, and adapt them to the support handle or extend them out from the 3/4 bar with a machined 3/8 tenon. I super-glued 3/16 HSS cutter tips on the angle desired. They only need to be 5-7 inches long, 3/8, 1/2, or 5/8 inch dia. Dont hesitate to call me for details if you want to try these.
The problem with these small shafts are the cost, and they cant get extended over the tool rest very far without vibration. So I usually cheat and do Christmas ornaments with the 3/4 boring bar through a larger hole and use the finial base to cover the hole.
Hope this helps.
Regards,
Lyle
lylejamieson.com
