Sort of turning related....
>After all it is a lathe, right? Finally, I am getting my ductwork done.
Re: Sort of turning related....
>Here is a picture of the track lighting that I have above my lathe. I am using the "Bright Effects" compact fluorescents (PAR 30).
JKJ in East TN
>Good idea on the track lights - I knew I was saving my old track lighting for a good reason!
I've been using bright fluorescents in individual fixtures for some time now and they are great and don't dump out nearly as much heat. Several people told me not to use them for lathe lighting because of the strobing effect but I found that not to be a problem.
RonZ
>I don't use flourescent by my lathe becuse it hides scratches and other unsightly things that until taken out in the sun or to regular light, look good. The main lighting is flourescent though.
Re: I've got a window for that...
>right behind the lathe. I let you know how these compact fluorescents work. Right now they are looking pretty good.
Same thing, different place
Raymond Overman in SC
>I picked up a used Jet DC1100 off of Craigslist this past Saturday and got the tubing run and everything in by Sunday afternoon. I configured mine a little differently. I'm ready to put it to good use now.
JKJ in East TN
>>I don't use flourescent by my lathe becuse it hides scratches and...
I actually mix bright compact fluorescent bulbs with 250w tungston mounted up high, all mounted in reflectors. The brightness and overall color temperature is better than adequate. Note that the new compact fluorescents have improved light output.
But I find scratch and defect detection more a function of the position and direction of the light rather than the color temperature, point source better than diffuse. (Long fluorescent tubes in diffusing fixtures are the worst.) What works well for me for looking for scratches is a bright flashlight or hand-held light that can be moved around to direct glancing light over the curved surface at varying angles.
