>We've had 4-1/2" since Saturday morning. This is on top of 2-3/4" earlier in the week and almost 5" two weeks ago. More heavy rain is expected later today.
The rain two weeks ago soaked in - we were pretty dry. But this is getting ridiculous. It's times like this that I'm glad I live on a ridge top.
I guess we won't be worrying about drought or forest fires for a while.
>You can have the rain in the chicago area as well. Took my daughter to the airport only to find her flight cancelled. I live in NW Indiana and we got pounded on wed night. Power was out for 24 hours and some still don't have it back yet.
>Brian, not to one-up Carole (I sympathize with you Carol and hope it rains on both of our parades soon) but Lake Superior is at the lowest level since 1890 and the governor asked the feds for disaster drought status for Vilas and Iron and other counties. A burning ban went into effect last night at midnight, as some of the bog fires are starting and difficult or impossible to extinguish. I talked to my brother-in-law this morning in Fountain City and offered you unfortunate folks a place to send the water; he said he would do what he could. Keep the house and shop dry!
>I've been in Minneapolis since Thursday night and its been raining here since Friday. Too wet and cold for August, even in Minnesota! This is September/October weather. My daughter tells me its been raining all weekend in Normal too. I'm driving back to Normal tomorrow and I expect it to rain most of the day.
Wish we could send it to you Carole. We've just had too much.
>The combination of heat and drought has made this summer the worst in memory in East TN even for longtimers (I've been here just under 40 years so I'm a newcomer.)
The fields are scorched and crops are worthless unless irrigated. Hay is going to be extremely scarce and expensive this year. (The small fields that usually give me over 200 bales provided only 56 bales this June.) In the last couple of days I've hauled over 1000 gallons of water from the river in an attempt to add a bit of moisture to some small areas of my horse pastures - going after another truckload in a few minutes.
As much as I hate to see tropical storms building, we hope that if one does hit the US it will skip over the coast and push some moisture this way.
>I switched the fan to your direction. But it doesn't seem to be working. I just watched the NWS radar loop from Duluth and everything was fizzling out before it reached you.
>I woke up this morning to 2" of water over the bottom edge of our furnace. The sump pump failed to kick on because the GFI it was plugged into had tripped. I reset that, was happy to see a good flow of water coming from the outlet but that only lasted a few hours. The cheap little submersible had given up for good.
So, knowing that sump pumps had to be selling like hotcakes, I called around to find one hardware store with a shipment coming in later that afternoon. It was normally a half-hour drive to Viroqua, except for a detour today to avoid a stretch of road below a small dam which was at max capacity and about to give out. No signs, just blockades, and I had to poke around on the back roads to find a roundabout route. I got into town with the fuel warning light on, to find out that the shipment had been delayed 3 hours!
Went and filled up the tank, killed time in various ways, then back to the hardware store which already had a good crowd of folks waiting for not only pumps, but generators, and shopvacs. It was an emergency shipment and they were gracious enough to keep the store open until 8 pm on a Sunday. I left home at 3:15 pm, got back at 8:30 to install the pump.
We got off easy, being on a ridgetop. The small town of Gays Mills downstream was completely surrounded by floodwaters, and is basically in a state of emergency. A few other area communities are in similar situations but less crucial. And it's raining again tonight, but not pouring (yet).
>YES! All you can spare. In Kentucky, we are like 16" under our normal annual rainfall. We got about 1/2 last night! It was great.......almost made me want to go outside and run around in the rain nekkid.
