Turn a 4' piece on a 3' lathe.
Kevin French, Antrim, NH
>I don't turn a lot, mostly to repair simple pieces. I am working on a chair for SWMBO and I need to turn 4' rear legs, My lathe is a noname 3' tube bed. I remember seeing a center piviot jig/end that made this possible. Any ideas on how to do it?
Re: Turn a 4' piece on a 3' lathe.
Start with a friend who has ....
Ed Moore
>a lathe with an extended bed. Offer them bribes. Don't jerry-rig something unless you have incredible dental insurance or a fondness for your dentist.
Ed
Re: Start with a friend who has ....
Lan Brady
>Kevin,
I understand Yankee Thrift, but Ed had given you wise advice!
Lan
>Kevin I've done that a couple of ways. The easiest was putting my mini lathe tailstock to tailstock with my big lathe. Both were Nova's at the time so the tailstocks would fit either lathe. Then I bolted them together with 2x4's and made a wooden tool rest the full length.
Before that I had a Delta 36" and needed a longer spindle. I bolted the tailstock to my drill press and move the bed up and down until I got the height right and the length close enough to use the quill feed. Then I codgered up bracing system between the two and turned a tall lamp.
Ideally you could find a machinist who could make a bed extension for you. That might cost as much as buying a used mini lathe however. Since it's a roundbed I would play with the idea of turning a wooden extension. It wouldn't hold up very well but would get you through this project.
Dave Peebles Lyons, Ohio!
>Kevin,
Some good ideas so far. But it may make more sense to try to replace your 3' tubes with some that are slightly longer.
I remember reading of someone doing that. But getting some time on a friends longer lathe may be the best solution.
Good luck with it,
Dave
