A55 Smoothing Plane
Time to purchase a rotary power carver
Paul Zerjay
>Would anyone have a suggestion on a purchase of rotary carver? Something small enough to do piercing, but enough muscle to remove material quickly. Thanks in advance
Re: Time to purchase a rotary power carver
>Paul I'm not sure any one tool fits both. I can do a lot of work with my Dremel. It's light enougth to pierce but with the right bit will get rid of wood pretty quickly. Here's the dilema. The Dremel doesn't do either that well.
I have a couple of flex shaft machines. They have much more power and remove wood a lot quicker but even that is slow compared to an angle grinder with either the full size cutters or the mini cutter.
For piercing, nothing beats the 400,000 rpm air grinders. The slower speed tools want to follow the grain when cutting so you are constantly fighting this and it's very tiring. With the 400K cutters it's almost like writing with a pen. It very relaxing to use(although it sounds like your at the dentists office).
If I were to buy one machine to try and do it all it would be a Foredom flex shaft. It has enough power to hog off a pretty fair amount of wood but is controllable enough to take very light cuts. If your good at making the wood very thin, (I'm talking 1/16 or thereabouts) then the foredom will pierce the wood pretty well it will just be slow going and take a lot of patience.
That's my take. I'll be interested in others opinions. I'm always looking for the ultimate tool.
Carole Valentine
>An alternative to the Foredom is the heavy duty Wecheer. They are very well made and powerful and they don't cost nearly as much as a Foredom. I have one and love it. You can get a regular handpiece, a pencil type handpiece and a reciprocating carver to go with it. The starter blades that come with the carver stink though - you have to get some decent blades. I think Jennifer Shirley has one too.
Re: Time to purchase a rotary power carver *LINK*
Bob Elliott
I purchased this unit about 4 years ago & am very satisfied with it. At the time, all of these hand pieces were not included in the bundle.
Also at that time, no one but Wood Carvers Supply offered a 1/3 hp motor.
Opted for this unit for a couple of reasons:
1) did not want a gas pedal
2) my purchase supported the little guy
Wood Carvers Supply, Inc.
