Electrical / Mechanical Lathe Questions
Ken Romines
>I have a 1 1/2 horse 230 volt Emerson motor to mount on the 12� Delta lathe I am trying to rebuild, but alas, I am a nurse and a wood turner want to be, so I need an amen before I do something really, really dumb.
The motor label has the following info schematic:
Blue ---------L1
Brown ---------Insulate
White / Orange -------Insulate
Purple / Red --------Insulate
Black / Yellow--------L2
To Reverse Rotation Interchange Red and Black
I also have two Siemens 42CF115AG contractors with an interlock to reverse the motor.
Question 1. I connect my two hot wires to L1 and L2 on both contractors. On the out L1 side of both contractors I run one wire to L1 (blue) on the motor. On contractor A I connect L2 to the Black/Yellow lead and that will get me my forward rotation. Do I run the lead from contractor B to the Red Purple leads to get the opposite rotation or ?????
Question 2. The motor will run 1725 RPMs with a 1 1/2 inch pulley on the shaft. I still have the Delta Variable Speed (Reeves) drive shaft connected to the lathe. Will this slow down the speed too much? I want to turn bowls and hollow forms when I get this finished. There won�t be a large number of spindles turned.
Does this make any sense at all?
Thanks again in advance for all the information/knowledge and inspiration you guys and gals provide.
Ken
Re: Electrical / Mechanical Lathe Questions
Bill Howatt
>My take on it is that you:
Connect L1 via the main contactor to the line as you described.
The output of L2 on the main contactor then feeds your interlocked contactor. This contactor is wired such that for the Forward state as per your table, the Purple and Red are connected and insulated (no power applied). The L2 power is applied to the Black and Yellow via the main contactor.
For the Reverse state, the Purple and Black are connected and insultated. The L2 power is applied to the Red and Yellow via the main contactor.
Your task is to figure out how the above is done with the interlocked contactor's connections.
Red Black
L2--Yel \ / Purple--
Black Red
I would guess it is something like the above which is a standard double-pole, double-throw reversing configuration. Above it is shown in your forward configuration. The L2/Yel wire is connected to the Black via the switch and The Purple is connected to the Red. When the switch is in the other position. The L2-Yel is connected to the Red and the Purple is connected to the black. The interlock ensures you can only be in one position or the other so the various wires don't get shorted together when the switch is thrown.
As for speed. Try it. Low speeds are very handy for bowl turning whena the blanks are out-of-round.
Diagram screwed up.
Bill Howatt
Re: Diagram screwed up.
Bill Howatt
>See if this helps. Sometimes it isn't easy to see what internal connections are present in some devices so be careful. The mechanical layout may bear little resemblence to the diagrams layout.
Bill
