tolerable tolerances?
Mike Hamilton
>I dug out my magnetic base and dial indicator from storage with the intent of checking my new Jet 1642 for spindle runout. Happy-happy, joy-joy. Measured in the race behind the threads of the spindle, I get less than .001 inch swing.
I threw on the Jet 1.25x8 to 1.0x8 reducer I bought a while back at a particularly good sale (knew I'd eventually have the 1642) and measured in the same place. The swing is .006 from high to low. Should I live with this or take it back? I have no clue what is tolerable.
Thanks,
Mike Hamilton
Plainfield, IN
Re: tolerable tolerances?
error multiplies
TDaniel
>I think by the square of the distance or something like that.If both pieces have a shoulder that is machined that would pull some of the error out. I doubt that getting another one would be better and it could easily be worse than what you have. It gives you a good reason to update to a better lathe sooner. :)
Re: error multiplies
Mike Hamilton
>TD,
I imagined that .001 was not too bad but the .006 was on the reducer/adapter. I assumed then that the issue was with the adapter. Both it and the lathe are brand new. I don't know of a "better" lathe without wiring for 220. Am I wrong about the .001 runout on the spindle being tolerable?
Thanks,
Mike
for the price you paid
TDaniel
>I don't think you'll find anything any better. A typical ball bearing will have that much play.
TD
Russ Fairfield
>0.001 is an acceptable run-out for a lather spindle. You will never see it, and it will never have an effect on drilling or a shor piece of wood.
Remember that the 0.006" you get with the adapter means that it is only off by 0.003. or about the thickness of a sheet of paper in your printer. It is -0.003 on one side and +0.003 on the other, for a total of 0.006. That would also be acceptable for an adapter. The problem is that you don't know whether it is the adapter that has the error or the threads on the end of the spindle. My experience with adapters is that they usually have far more runout that 0.006" when they are screwed on the lathe.
As an example of better, there is 0.0005 total runout in the spindle of my Oneway, and the adapter (also from Oneway) that I use is accurate to within 0.0015. The difference is that I paid $3,000 more for my lathe than you did for your Jet, and I should expect to be getting something for my money.
Live with it .
Ray Thompson - Middletown,IN
>It's woodworking not gage work, besides, your name is not Al.
Ray
>Mike I intended to measure my lathes today but didn't get around to it. I've turned on lathes that had lots of runout and lots of vibration and I did quality work. it's much easier on these lathes that don't have all that vibration and such but I haven't actually measured the runout.
Doug Thompson near Cleveland
>Mike, remember TD turns on a VB and that's the best on the market. For the rest of us runout like that is just fine.
I've wondered what the TIR is on a turning, (before it warps) not that it matters just curious.
Re: thanks all
Mike Hamilton
>Thanks for all the responses. No, I am not AL. But I did have the technology to measure the runout. Unfortunately, I had no reference for interpreting the data. Therefore my query to the accumulated knowledge/wisdom here. I think maybe I'll just turn something tomorrow.
Regards,
Mike
Re: thanks all
Jennifer@Indy.USA
>Mike, put the measuring stuff away. Remember as turners...we don't need no stinking measuring tools!
Enjoy your day turning :)
Jen
