REAL MILK PAINT
Undecided!!!!!!!
Undecided!!!!!!!
Undecided!!!!!!!
Barry ... on SaltSpring
>Hi All I have been using the DonPencil hollowing system for about a year, and very happy with the results. But now I am ready to try a captured rig with laser. I think I am narrowed down to either the "Elbo" or the Lyle Jamieson rig. Has any one had experience with both? Is there something else I should consider. Any and all comments greatly appreciated.
TIA Barry
Re: Undecided!!!!!!!
Norm Smith in Nova Scotia
>I have a Jamison type system which I find OK, however I bought the Elbo system about 2 months ago and love it. It is very smooth and a pleasure to operate.
Good luck,
Norm
>Barry,
I designed and built my own "Jamieson" style rig for all of about $90 including the welding and the laser pointer. It has a sliding trap and will take hollowers sized 3/8", 1/2", 5/8", 3/4" and 1". I'll try to post a couple of pics later if you like.
mm
Brodie Brickey
>Mark,
I'd definitely be interested.
Brodie
Re: Undecided!!!!!!! *LINK*
Pat Taylor
>I like the monster system made by Randy Privett
http://www.monster-wood-tool.com/
Here goes . . .
>The setup is made from 3/4" cold-rolled round bar for the "D" brace and the upper capture bar. The tool socket is a 3" piece of 1" DOM steel with a 1/4" wall thickness to take a good thread. I used 1/4x20 hex bolts to fix the tool and laser boom holders because knobs would not hold things tight enough, and hex keys are a pain when the start to round off with a lot of use. The capture slide is made from 1-1/2" angle iron with a couple of pieces of 1/4 x 1-1/2" plate welded on the ends. The laser boom support is a piece of 3/4" steel pipe, and the laser boom is 5/8" galvanized conduit. The articulated laser holder is wood, with the pointer held in with a pair of small grub screws. The pointer's switch is activated by the thumbscrew.
1st pic is of the tool holder and behind it the laser boom holder attachment.
Re: Here goes . . .2
>This is the laser boom fitting that sets both height and extension. Just 2 pieces of steel tube welded at 90* with a couple of 1/4x20 nuts welded on for thread.
Re: Here goes . . .3
>Opposite view of the boom elevation attachment point
Re: Here goes . . .4
>This is the trap. The top bar is adjustable to give clearance. Simply center drill the bar and tap for a 3/8" thread. The ratching handles were 80 cents each. There's a piece of UHMW glued to the angle iron which lets the "D" handle slide like silk. The top bar is wrapped with heavy polyester for the same reason. Very little friction in this rig.
Re: Here goes . . .5
>This is the bracket that hold the angle iron but allows it to slide. Made from a piece of 3/4" bar stock that had the 1/4" slot cut then welded to a 1" post to fit the auxilary banjo. Used two clamping levers to prevent the rig from rocking around a center point. Also uses a stop ring on the post to preserve the setting height.
Re: Here goes . . .6
>This is the articulated laser head. made from a block of maple, a piece of dowel, and a wingnut.
Couple of Notes
>1. The laser boom is filled with urethane foam to help with vibration and give more rigidity without adding weight.
2. I had to change the boom holder strut from a nice piece of moly tubing to the 3/4" pipe to improve the vibration situation. The smaller stuff flexed too much, but the heavier pipe does much better. The holder's height is just enough the let the boom clear my large steadyrest.
3. Took a piece 4" of 1" drill rod and drilled 3/8" and 1/2" holes in the two ends plus a set screw for each to hold smaller tools. This fits nicely into the main tool socket on the "D" handle. I use a 1" to 3/4" bushing to hold the 3/4" tools like Jordan and Pencil hollowers.
Hope this helps.
MM
His Handles look fantastic!
Jennifer@Indy.USA
>thanks to all who responded, your comments are appreciated
Barry .... On SaltSpring
Re: Couple of Notes
Don in Central Illinois
>Mark, dumb question. How do you register the laser pointer to the cutter? Just shine it on paper and measure the difference and then adjust the laser pointer to get the thickness you want? Don't have one yet, but think I could make one.
Re: Couple of Notes
>Hi Don,
I've tried to respond to your question 3 times now. Each time I'm about ready to post, another boomer roles hrough and I have to kill the computer! Maybe 4th time's the charm . . .
I first use the boom lock to get the spot off the tip of the cutter. I then use the articulation and a photocopy of a 1/16th" ruler to set the distance either from the tip or from the edge. Latly I tighten everything up and recheck to gap. If all's well, I start cutting.
Once tightened, the rig stays consistent at the setting.
mm
