small tool gloat
small tool gloat
small tool gloat
keith zimmerman, Normal, IL
>After 4 years of turning in my tiny closet/shop, I have finally figured out how to hopefully capture most of the sanding dust I generate. And, even though I wear a dust mask while sanding, I'm thinking that I'm starting to experience adverse effects from the dust.
For these reasons, I bought a Fein Turbo II vacuum and am setting it up to capture as much of the dust as possible at the lathe. I really like how quiet it is and it seems to do a really good job as a vacuum.
keith
Got to clear that air.
Re: small tool gloat
GeeSeaWhy
>Lacking room for a real DC, I've been using a Fein II for some time. I plug the drill into it and the vac starts and stops with the drill. You might be able to run the lathe through it but my Nova DVR is "always on" to the Fein. For hand sanding I plug a lamp in and use that to control the vac. After messing around with duct tape for a while, I made a holder for the hose nozzle. Just two bits of plywood with holes drilled for the nozzle, glued to slots in another piece of plywood with a wooden post on the other side of that to hold it in the banjo.
It works very well on most of the stuff I do, which is generally under 12".
Graeme
