How do you mount your nuts?
Dave Belser
>Now that I have your attention.....
I have a handful of nuts to turn and I'm interested to hear how others mount them. I'm sure that I could work it out but I might as well start from what other people do.
- Dave
Re: How do you mount your nuts?
Steven Antonucci
what kind of nuts?
steve antonucci
>I'm not getting what you mean...
Steve
Carole Valentine
>I have only turned a couple of tagua nuts. As I recall, I sanded a flat on the end and glued it to a tenon held in the chuck.
Re: what kind of nuts?
Dave Belser
>Steve I'm not sure what kind they are but they are all basically shaped like small eggs, no more that 2 1/2" long and a little more than 1" in diameter. One still has a husk or shell on it (like a coconut) and rattles when I shake it. Not sure what to do this one, I suspect I should take the husk off before trying to turn it. I have two of this type so I'll probably cut one in half to see what the inside looks like.
- Dave
Steven Antonucci
Got it now...
steve antonucci
>I wasn't sure if you meant turning "acorn tops" or actually taping threaded nuts or what...
I've had some luck with turning tagua nuts (vegetable ivory) by sanding a flat spot and CA gluing it to a waste block. Hit it with accelerant and let it sit for a a few minutes. Light cuts, sharp tools...
Steve
>Dave I'm picky about my nuts. I chuckle every time I say that. I've turned all sorts of nuts and other odd things using this technique. Here's what I do. I mount them between centers lightly. Then I adjust it until I get it where I think it should be. If I'm in doubt I will turn a little bit to check the alignment. I may move one of the centers very slightly several times. Once I've got the nut positioned exactly where I want it I turn a very small tenon on one end. It can be extremelly short because mostly the glue holds on the squared up shoulder. Then I turn or drill a hole in a wasteblock attached to my chuck. I glue the tenon in the wasteblock. This aligns it perfectly.
I've had very good luck turning crooked antlers for pen using this technique as well. the only difference is I drill the pen blank while it's on the lathe and aligned using the above technique.
that is the way i mount my peach pits
robert davis
Dave Belser
>That's exactly the sort of idea I was looking for. I've turned little bits of burl by pinching between two centers and was going to try something like that. The tenon and waste block sound like a good idea.
I went to college with a guy who was a bit of a clown, particularly if there were women around. Inevitably one of the women would say "You're nuts!" and his response was always a straight faced "What about them?"
I still use that line today when I have the chance.
- Dave
I AM ABSOLUTELY, POSITVELY, NOT GOING TO
Ken Oakley-Sunny St. Cloud, Fla.
>attempt to answer this one. I will probably suffer a massive heart attack suppressing the urge. AAAAARRRRGGGHHHH!!!!!!!!!!!
