>It's getting to be time to get an electric chain saw for breaking down logs etc (getting tired of gnawing them to a usable shape). Don't want to spend a lot. Have seen the Remington at HD and I know Sears sells one. I also saw one made by Ryobi which looked interesting in the same price bracket ($100+/-). Which would be my best choice? Interested in your experiences and/or advice. Thanks
>Watch out for the ones that have a plastic drive wheel. Remington and the HD ones do and they burn out readily under load. O.K. for occasionaly limbs but nothing heavy. I finally purchased a Makita and it is great. Sthil also has a good one I am told. Darryl
>I had a Remington from Lowes and stripped the plastic drive gear in a New York Minute. They replaced the gear and it lasted until the warranty ran out. I really babied it. I bought a similar one from Sears for about $89 plus $12 for a two year free replacement guarantee. I have used it much harder and it has held up. I think a lot of that guarantee. Have not had to use it. Magic.
I would be hard pressed to pay several hundred dollars for the Stihl and I REALLY like my gas power Stihl saws. Don't know what the Makita sells for, but at the price I paid for mine I actually don't
care if it dies after two years, I will just treat it as a disposable and get another.
I shouldn't, but I often run mine without oil in the bar oiler. Apparently it just drools oil without any pump or dispersal mechanism. So if you leave the saw sitting on the shop floor it makes a puddle, but only until all the oil is gone.
I haven't bought a gas saw yet (finances) but I picked up a 16" Troy-Bilt electric saw. I love it. I can bog it down if I am near it's 16" capacity but it keeps coming back. My only complaint is that when making a rip cut it can clog with shavings. Not a big deal in my eyes but it would be a pain if you were going to cut for 4 or 5 hours.
>I recently bought a Craftsman and in less than 10 minutes of use it broke. I got my money back and ordered a Makita. I trust that it will last longer. The down side is that the Makita is in the $200 - $250 range.
The low cost saws seem to be a real crap shoot. Some serve people well for a long time, but most break quikly. If you do get one, I hope it serves you well.
>I also need an electric chainsaw. I can't afford a good one. I'm wondering if I could replace the easily brocken plastic gear with one that I can make out of steel. I'm still new at this machining thing but it might be possible for me to build one.
>I recently bought a Makita UC3500 which is their 14" electric chainsaw. I got it to trim large blanks after I get them home. This saw has plenty of power and doesn't leak oil. The size is ideal for what I'm using it for. Price is around $180.
>Remington: I am on # 5 in about 2 years. The motor keeps burning up, but at least Lowe's has replaced it so far. Had a Sears for 25 years until I could no longer get parts.
>Makita, Husky, Stihl, and Milwaukee have good electric chainsaws and they will cost about $200 to $250. They have more power than the cheap ones, better oilers, better braking, better drive sprockets, etc. The bottom line is to buy what you can afford but if you can handle the price any of the ones listed above should serve you well.
>Ed, I have had the Ryobi from Home Depot for a few years and am satisfied with it for the price. I ended up taking the kickback safety bracket off the end of the bar. With a fully charged battery and a sharp chain, it works fine for its size for small and short-time jobs. Have taken it partially apart for cleaning and did not notice any cheapo parts. My main complaint is that I cannot find a replacement chain.
>I went thru 3 of those Remington POS saws. Good only for an OCCASIONAL limb here and there. Finally got a Stihl MS180E. Expensive, but the last elec saw I'll have to buy. Steel drive gear, slip clutch to protect motor, inertia chain brake in addition to lever brake.
I went one step further (hey, I never leave ANYTHING stock) and replaced the stock .050 gauge bar with a .043 gauge bar (same as my MS170s use). This allows using a thin kerf (Picco Narrow) chain. Less wood to remove equals faster cuts and better performance. Works really well.
Years ago I bought a Stihl E-220, their top of the line electric chainsaw and I have never regretted it for a moment. I use a 20" bar on it normally, but I have also used a 32" bar on it numerous times (the same bar that fits my 066) when working with larger logs and/or cutting crotches. In about seven years of use, it has not had a single problem. It has the power to cut very hard wood, even with the full 32" of bar buried in the wood. Money well spent in my book! :-) Take care and all the best to you and yours!
