Kwila bowl
Kwila bowl
Kwila bowl
Tommy Holmes
>I finally got around to making a phrugal photo booth so I could start posting pictures. Not that I know what I'm doing with it and I'm basicaly using a point and shoot camera.
This is a kwila bowl about 5-1/4" x 2" with a 1/8" foot. It is about 3/16" thick except at the top where I got thinner. I wanted to go thinner but had just cut through a bowl of this same design and chickened out. The finish is several coats of lacquer.
Open to critique on the bowl and the photograph.
Re: Kwila bowl
Re: Kwila bowl
Bob Fawcett
>I realy like the bowl.
I am not qualified to comment on the photo, But I will anyway. The highlight right in the middle is probably not what you want. The light source should probably be to one side.
Jamie or John can tell you how.
Re: Kwila bowl
Re: Kwila bowl
Cyril Griesbach
>A very nice bowl and well finished as well. Sans the "headlights" the photo is fine.
Re: Kwila bowl
Re: Looks like you didn't...
Jamie Donaldson
>... (or maybe couldn't) turn the flash off- that's what caused the center highlights and hard shadows. Many P/S cameras don't allow manual flash control, but check the book if you still have it. Then the other problem may become color balance for the artificial light!! Nothing is ever as simple as it seems!!
Re: Kwila bowl
Tommy Holmes
>I was hoping you would comment Jamie. You're right I couldn't turn off the flash checking the settings on the camera. I'm using a Sony Cybershot. I'll check the manual and see if there is another setting somewhere. The color balance choices were automatic, natural, snow, beach and a couple of others that didn't seem to fit. I'll keep reading and fiddling with it.
Re: Kwila bowl
Re: An option with the flash is to ....
Jamie Donaldson
>.. diffuse it with a mask of some opaque material like a piece of a plastic milk jug. The plastic held in front of the flash tube will spread the light, but experiment to see if it also causes an exposure error.
Re: Kwila bowl
Tommy Holmes
>Thanks Jamie. I'll try it.
Re: Kwila bowl
Re: Kwila bowl
eaglesc
>It LOOKS like it would hold soup so I guess it isn't Art.
Regaedless I think it is elegant.
I like the simple shape.
(Looks like it would hold guacamole dip too.)
Picture is crisp and clear/uncluttered.
(But what do I know, I only make pens)
Re: Kwila bowl
Re: Kwila bowl
eaglesc
>Oh yeah, a piece of scotch tape over the flash will diffuse it also.
When pens are photographed I look for the"flash line" it can idicate how well the finish came out.
