A few years ago a guy did a demo at our club meeting and showed how he used CA as a finish on small items such as bottle stoppers. He confirmed what I had already experienced: if you use a celulose product (cotton, rag, paper towel, etc.) two bad things can happen. One, the glue reacts and sets up too quickly, and two, the reaction is exothermic and releases a LOT of heat. This can be enough to burn your fingers and even smoke the cloth.
His solution: use a synthetic material instead which does not react with the glue. He recommended bits of a material used as padding for upholstering and bedding. (sorry, I can't remember what it's called) It's white and looks a bit like a thick layer of cotton fibers. To apply, he holds a tuff with hemostats to keep it off his fingers and applies while rotating the lathe very slowly.
I've tried this a few times and it works fine. However, I usually use the Myland's friction polish (shellac) instead since I found it more controllable. The CA ought to hold up better, though, especially where the finish may come in contace with alcohol. I do use CA to seal up problem grain (with goggles - the vapors wipe out my eyes!)
I have used CA on bowls and such for cracks and used it with coffee grounds to fill small holes, but never as a finish. I can usually apply it straight from the bottle for that. Haven't tried to use it as a finish, and wonder how one does that.
So far I have used friction polish on small items like pens, and I use it on the tool handles I make, but I am not worried about durability on tool handles.
>I use CA as a finish on pens made from deer antler. I apply thin while the lathe is turning with a VIVA paper towel below. I am very liberal with the CA and the heat generated along with the cellulose in the paper towel act as the catalyst for it to set up. I usually apply two or three coats to build up the finish.
I have used CA to finish pens and other turnings up to a 5"dia x 7"h vase. I cut the finger off a latex glove and use it to spread the CA. I put the glove finger over my index finger then apply a small amount of CA to my covered finger and rub it over the turning. I repeat this until the piece is covered. I have had no problem with heat or premature setting up.
I have used this technique with both water thin and medium viscosity CA. Both work well. As you would expect the thin spreads easier.
On larger stuff I would make sure the area is well ventilated and that your eyes are protected.
Metioned by others. I use polyester batting fiber from WalMart. It comes in bags used for stuffing pillows or animals. Pinch off a small amount and grab it with hemostats. 2 or 3 drops of CA and apply in a circular motion until you feel it start to stick. Add 2 more drops of CA.
After it dries, lightly sand and apply a second coat. Most items have been completely smooth with 3 coats. It polishes great.
>I try to use the back of sandpaper but usually end up with just my middle finger. Put the bottle against the turning on slow speed then use use paper or finger as a squeegee to run a thin coat up to the top of the turning. I'm thinking a block of rubber might work even better. Use exhaust system and don't wipe your finger on your good jeans.
Or... I was using the "finger" application method once when I got a phone call on my cell phone. After flipping it open and taking the call, I found I had glued my finger firmly to the front of the phone!
