200+ woodworking book reviews
vacuum chuck
vacuum chuck
vacuum chuck
Al Czyzewski
>I found on the web at one time a vacuum chuck which fit over the lathe spindle. I have lost the bookmark. You used a shop vac to provide the vacuum. I can not use vacuum through the spindle, it is solid. Does this ring a bell for anyone? Let me know please.
Al
Re: vacuum chuck
Vicmarc Maybe? *LINK*
Gerry Meekins
>Al,
I don't know if this is what you are looking for, it's the only one I know of that works with a shop vac.
Gerry
Vicmark Vac Adapter
Re: vacuum chuck
Re: vacuum chuck
John Scheideman
>One of the vendors at the woodturning symposium in Portland had one. I'll try to look through my fliers and see if I can find it for you.
John
Re: vacuum chuck
Re: vacuum chuck
Al Czyzewski
>Thanks to all who responed. The Vicmarc was it. The Vacuumaster Chuck would work but is too expense for my budget. Al
Re: vacuum chuck
Re: vacuum chuck
John Scheideman
>I found my information from the symposium and, as you found out, it was the Vicmarc. The info that I picked up says it is priced at $119.95. Their number is 702-871-0722 (Las Vegas, NV) or 702-567-8223 (Henderson NV). Those numbers are for Woodworker's Emporium, who was the vendor at the symposium that was demonstrating the vacuum chuck. Hope that helps.
John
