Ready to begin! (woohoo!)
Carol - Strawberry, AZ
>Finally!
I have settled (for a year in north central Nebraska) and I brought my mini-lathe with me. I have never used it!
It has been three years since my first lesson from Wally and over a year since I even held a turning tool. So consider me starting from scratch.
I have some dry stuff to practice on. Now to mount it. I have a screw chuck thingie, a couple of face plates, and a lathe chuck. Where to begin?
Here come the questions, folks.
Since my only experience (what little there has been) is with bowls, I will stay with that. Is the top of the bowl the pith side of the blank?
If I remember correctly, Wally had me bore a hole into what would be the top of the bowl and turn in the screw chuck. Then flatten the bottom. Then glue on a waste block. Mount the face plate on the waste blank.
Am I OK so far?
Re: Ready to begin! (woohoo!)
Good so far.
TDaniel
>Start the turning by taking wood off from the corner nearest the tailstock. Move the bowl gouge from right to left with the flute facing left, using the bottom half of the tool; you'll have to twist the tool back and forth until you find the sweet spot. Don't bump the tool on the return. GO!
TD
>Carol Glad you back turning, and settled. You are correct in what you remember Wally teaching you. You can turn a bowl with the pith on either side it simply changes the way the grain patterns appear.
Since you have a chuck you can also turn a tenon on the bottom and grab that with the chuck or you can turn a recess and expand the chuck into the recess. There are a lot of different ways to hold a bowl.
Carole Valentine
>Glad you are settled for a while! I certainly am not one to tell you to do it differently than the "Master", and glue blocks are great tool, but I don't usually bother with them. On a small bowl, I will either just start it between centers, or with a screw chuck and turn a tenon on the bottom for the chuck. On larger ones I may use a faceplate on what will be the top of the bowl, turn the tenon (or recess) after a general shaping of the outside of the bowl, flip it into the chuck and then go from there. Usually I put the pith at the top of the bowl and turn it out. Keep this in mind when developing your form. Just my TCW.
What Took You so Long?...
Wally Dickerman in Arizona
>Carol,glad to see you back to spinning wood. Your memory serves you well.
Folks, Carol can spin 'em either way...she turned her first bowl on a mini-lathe at Sophie's BBQ, her second on my "lefty" Nichols lathe, and her third the very next day on another mini-lathe. Took to it like a duck to water.
Remember, aim the flute in the direction that you're cutting and rub the bevel.
Any questions, just ask.
Wally
Re: What Took You so Long?...
>Thanks, Wally.
I have been at seminary the last two years. No place and no time for tools of any sort. :(
Now I am on internship for a year and I packed my mini-lathe. It may be slow ramping up, but it looks like I will have some time. YeeHaw!!
I do remember about rubbing the bevel and pointing the flute. Thanks. And you can bet I'll be back with lots of questions.
Now Wait Just a Minute! *LINK*
Jennifer@Indy.USA
>Miss Carol, has your memory forgotten the lovely pen that you turned in January of this year? I shall refresh it for you :)
So happy to hear you're closer than ever to spinning some wood! Woohoo!
Jen :)
Click here for Proof of Carol Turning in 2007!
Re: Now Wait Just a Minute!
>Mia culpa! I did forget. Sorry, Jen. Something about learning Greek and Hebrew that warps the brain. :)
Not only did I enjoy turning the pen, but I enjoyed the company even better! :) Thanks again for your hospitality.
Jennifer@Indy.USA
>Carol, any time you're in the neighborhood you know that GPS will get you here. Hope the pen is helping you study and receive top scores come exam time!
I still haven't turned that hunka hubba bubba wood you sent me. It's waxed and wrapped and ready whenever I get to it though.
Happy Turning :)
Jen
Bill Crommett
>What, no Aramaic ?
>Gimme a break, Bill! As if what I just had to do wasn't hard enough. I am a few months shy of being eligible to collect Social Security. Never did I think I would do what I just did, and frankly, I am more than surprised that I survived!
I need to get back to woodworking of some nature to retain some sanity!
