How to Spalt Maple
How to Spalt Maple
How to Spalt Maple
Sean Troy
>How would one go about spalting some fresh cut maple log sections? Thanks for any help, Sean
Re: How to Spalt Maple
Bill Grumbine (Kutztown PA)
>I get it all ready to go and pretend like I'm really going to do it. By the time I actually get to it, it is spalted! Seriously, I just leave it lay, and it seems to spalt on its own most of the time.
Bill
Ric Taylor
Ric Taylor
>Sean,
Spalting is not an exact science, but rubbing some dirt on the freshly cut surface might help, or standing the log on end with the freshly cut surface in contact with the ground. Sometimes it works, sometimes it doesn't. Don't expect results overnight, it might take weeks or months.
Ric
Sean Troy
>Would I Anchor seal one end and place the fresh cut end down on the grass/dirt? Tarp it? We've be unusally dry this summer.
Re: How to Spalt Maple *LINK*
Russ Fairfield
>What works in PA may not work in AZ where the humidity is near Zero, and the last rain fall was in 1969. The fungi that cause spalting require heat, moisture, and food. Maple spalts easilly so the least you might want to do is put the wet wood in sealed plastic bags to retain the moisture. You can make it more positive and faster by giving the fungus a start and some food as described in the linked article.
Another way to get good spalting and have control over the type and color of the spalting is to insert mushroom starter plugs in small holes drilled into the end-grain.
http://www.woodcentral.com/russ/russ4.shtml
Re: Mushroom website *LINK*
Russ Fairfield
>I forgot the website for the place I recommend for mushroom starters for spalting wood. Give them a call. They are familiar with our needs for spalting wood.
http://www.fungiperfecti.com
Mike Cunningham (Cape May NJ)
>I've placed maple and beech logs on moist earth in shade behind my shop and attained satisfactory results. It took close to a year and I kept an eye on it to avoid rot.
Mike
George Van
>Shawn, I put my logs cut as long as I can get them, usually 16�-20� on the ground, in the shade on a layer of shavings from the lathe (keeps them cleaner and has lots of spores) and turn them about 4 times a summer to equalize the moisture which settles to the bottom. After about two years up here they are ready to rough turn. White birch is more unpredictable. I would imagine down there where it is warmer it will spalt more quickly. I do not coat the ends of the logs and loose about 6� when I am ready process them. I have had good results with the birches which hold moisture well by just covering the pieces, stumps, logs, whatever with a tarp and not turning at all.
Sorry.....Sean
George Van
JKJ in East TN
>Sean,
You might search the archives here for past messages - I remember a lot of discussion a couple of years ago.
From what I understand you need moisture, air, warmth, fungus spores, and time.
The fungus you need should be everywhere under leaves in the woods, but some people concoct a brew to encourage it. If the climate or season is very dry you may have to add moisture and keep the wood under a loose tarp to keep it from drying too fast. I understand the fungus grows in from the ends so it seems to me that cutting a long log into shorter pieces might help. Note there is a fine line (no pun intended) between beautiful spalted and worthlessly rotted wood. The wood must be processed at the right time before the decay progresses too far, but I've never heard of a sure way to tell when it is ready without cutting it open.
From my personal experience I followed someones advice and buried a figured maple log in the ground for a long time and got zero spalting. (Probably insufficient air) I had other pieces from the same log laying in the dirt and leaves in the shade and they spalted beautifully.
Richard Allen
Richard Allen
>Spalting maple? Process the maple in the usual way Making slabs of desired thickness is good. Stack and sticker off the ground in the shade and cover with a tarp. The blanks at the top of the stack will spalt first. Takes about a year, but checking the progress every few months will give you the experience needed for your conditions. If spalting isn't detected after the first couple of months you can hose down the stack and add dead leaves to the pile.
Jim Swank
>You've had a lot of good information. I'll add one more piece. If you want to spalt wood, cut it in the spring or early summer while there is a lot of sap and sugar in it. If don't want it to spalt or if you want it to dry quickly, cut it in cold weather after the leaves have fallen. Almost everything spalted spontaneously in Arkansas for me. Nothing spalts willingly here in Milwaukee.
Gary Evans Tallassee, TN
>Hi Sean,
I am fortunate that I have some very attractive fungi where I store my wood, which just happens to be on the bank of a creek. Off the ground, but in a relatively humid spot, and then let it lay for about a year. Like JKJ said, the only way to know what you have is to cut into it, but if you let it lay for a year in East TN, you should have some pretty wood. Your conditions may vary.
If you want some spores from some pretty wood, let me know and I'll send you a bag full.
Gary
Sean Troy
>Thanks everyone for all the great info. I'm going to have some fun trying this. I just found a new tree trimming contact and he dropped off 3- 10' Maple logs around 16-17" in dia this evening. He said I could have all I want and to just call him when I'm running low.
Jennifer@Indy.USA
>Sean, my friend Betty wraps the log in a dark plastic leaf bag and then sets in on the splash pad at the bottom of the down spout. Check on it every month or so. She says it works great.
Jen
