Waxed blanks question
Bob Way, Canton, MI
>At last year's Louisville Symposium I picked up a 3 x 3 x 12 Brazilian tulipwood square from one of the vendors. It is coated in a heavy wax. I started to prep a small piece of it for a project and cut off what I needed on the bandsaw. But, oldest son and delightful daughter-in-law showed up and seduced me out of the shop with a trip to the ice cream parlor (I'm so easy). I set the blank down and when I came back to it next day, I noticed the end of the remaining bigger chunk had developed a fairly decent crack in the center of the cut end.
So, my question is should I have removed the wax or done some other prep work with the square before hand to help it stabilize?
Bob Way
Canton, MI.
Re: Waxed blanks question
Mike Stafford
Mike Stafford
>Bob, waxed blanks are almost always green or mostly green wood and the blank is coated in wax to prevent the moisture from leaving the wood too quickly and causing the uneven drying that results in checking.
When I use blanks like this I cut off my piece for turning and wrap the remainder tightly in plastic wrap making sure to carefully seal the ends. Then I rough turn and rough hollow the blank ( I use sticks of wood like you describe for boxes) and soak the roughs in alcohol per Dave Smith's method described here on WC. I then take the alcohol dried pieces and let them dry to equilibrium in my water heater closet.
RonZ
>Unfirtunatly more and more blanks are coming wet. They cal it partly seasoned, they just never tell you which part. I recently fot a big block of ebony from a 'famous place' in the US and prceded tp make a bowl for my mom. Well, I said to myself that heck, I must have become a world class turner overnight or my Tormek was working overtime. Beautiful ribbons were flying off the bowl. Well, when I got around to clearing someshavings off the lathe, there was rust on the bed. The ebony was wet!
Solution?
I personally keep a supply about six months behind, i.e. I keep these for at least six months and them turn them and there is more stock drying.
Bob Way, Canton, MI
>Thanks, Mike. That was one of my problem definitions but since this is my first time using waxed blanks I wasn't quite sure. It's a really nice looking piece of tulipwood so your suggestions will go a long way toward helping me with it. The alcohol drying option had completely slipped by me.
Out of curiosity, is anything gained from scraping off the wax beforehand? Other than a gunky mess to clean up?
And if one of my boxes turns out half as nice as yours, I'll be a happy camper.
Bob Way
Canton, MI
Bob Way, Canton, MI
>Hi Ron. A friend has a pole barn where one entire wall is covered with shelves for holding his supply of roughed out bowls. Got to be 10 ft tall, 15 ft long and just packed.
I have a couple of waxed bowl blanks, in addition to the squares. I'll try the alchol drying on a couple of pieces from the square, but if the bowls are too big for the process, setting them aside for a time shouldn't be a problem. Seems I always have a bunch of projects in one stage of completion or another lying around. Drying bowls would blend in nicely.
Bob Way
Canton, MI.
Mike Stafford
Mike Stafford
>Bob, I don't remove the wax until I turn it away on the lathe. I keep everything protected as long as I can.
Even if you do use the alcohol method some of the more dense exotics will check on the lathe during turning and even more so if you sand the end grain to vigorously and get it hot. That is one reason I have gone to using wax as a lubricant for sanding and as a finish on some woods.
Thanks for the nice words...
