>I finally got back in my shop this afternoon and decided to try turning a little spalted maple box. I jam fit the lid onto the body and finished turning the details but when I went to remove the top to do the final fitting, I can't get the top to budge. I'm thinking about putting it in the freezer for 15 minutes or so. I also thought about the microwave, but I figure that would cause it to warp or split. Any suggestions?
>Carole, the most unusual tool in my turning repertoire is one that you should have no trouble finding on the Eastern shore- a thin bladed fillet knife. I keep one on the magnet near my lathe just for this problem. You can carefully work the blade into the join line and pry it off a bit at a time as your turn the box by hand. Go around the join line carefully and pry it a bit all around the circumference.
Sometimes you can just sand the lid a bit with very fine sandpaper to get it a little warmer and it will expand enough to get the lid off. One word of caution make sure both the lid and the box body are at ambient temperature before doing a final fitting of the lid. If one or the other is hot from sanding the final fitting will not be a success.
>Thanks, Mike. I brought the whole works, chuck and all, into the house where it is a lot less humid. If I doesn't loosen up, I will try the filet knife. The box is nothing special.
>Carole I have also used Mike's suggestion. I put the blade into the wood on one side and then very carefully walk it all the way around the box. That usually gives me enough purchase area to get it open but if it doesn't I have a paring knife that is a little thicker. I'll use it to widen the gap and that has always worked. Automotive feeler gauges also work and you have a bunch of thicknesses.
>Have you tried one of those rubber strap wrenches? You have to put a rag under the hard plastic wrench body, but the rubber strap really get a grip. How about the chunk of rubber sheet you have in the kitchen for getting the lid off the pickle jar? One last idea, how about an added inlay, or tall finial, in the top of the lid. That would let you drill in a hole and use an air gun to pop off the top, add the inlay, and then turn and sand that flush.
