Low Voltage Problem update
TDaniel
>Once the electric company was notified of my low voltage they did everything possible to fix the problem asap. Yesterday they replaced my transformer; today they did something down the road, not sure what but it involved 3 bucket trucks, etc. At 3:00pm I was down to 105 volts; at 4:15 I was back up to 116 volts. In this very hot weather it would be worth anyone's trouble to closely monitor your supply voltage and keep a log if the voltage is less than 110/220. Your insurance company will not pay to replace your well pump, your A/C, your refridge or anything else if the problem is low voltage. You cannot ask your electrical company to pay for these unless you have supporting info to back up your requests. I am not a lawyer and don't want to become one, (too many friends to loose) but I think the providers of power are required to maintain 110 volts minimum or be accountable for damages. No records...no chance.
Re: Low Voltage Problem update
Allen Neighbors
>Glad you got the problem solved, TD. I've never checked mine, but when I get back from the show, I intend to. Our electric company choices in this area leave a lot to be desired, and we're always having power outages, lines down, and other problems of the like.
I don't want to lose any equipment... so I'm going to keep tabs on it.
Thanks for the heads up.
Terry Quiram, Roanoke Illinois
>TD
I had a low voltage problem a couple of years ago. The lines from the pole to my weatherhead ran through a tree in my yard. The tree had rubbed the insulation off and one leg was shorting out in the tree. The power company paid to fix the things that went fooie cablooie because it was "an act of god". They tried to argue with me and I pointout that they, not me failed to trim limbs. Plus everything after the weatherhead is mine. Everything in front belongs to the power company. They wrapped the lines with some type of plastic AND trimed limbs away.
Terry
Ric Taylor
How Does One Know?
Ric Taylor
>Stick a meter in an outlet? This city boy wants to know.
Ric
Re: How Does One Know?
JKJ in East TN
Yes. A cheap digital meter from Radio Shack works well. Be sure to set it for AC. Check between all three contacts two at a time. If the meter leads will not fit into the flat prong slots, you can insert a plug part way and touch the leads (very carefully) to the sides of the prongs.
The flat prongs should have 110v across them. You should have 110v between one flat slot and the ground socket. You should have zero (or nearly zero) between the other flat slot and the ground.
When checking in the circuit breaker/fuse panel, be very careful - one wrong move could cause excitement at the very least. (30+ years ago I melted, or rather, exploded a screwdriver in two once while working in a defective panel and I've never forgotten it.) It would be safest to get someone with experience to open and check the panel.
Fog Tanner
>Ric,
Bring your meter to the next meeting and I can show you how.
