Mexican cocobolo beaded box...
Mike Stafford
Mike Stafford
>I am not sure what distinguishes Mexican cocobolo from any other cocobolo except, perhaps, where it is harvested. This wood was extraordinarily dense and hollowed beautifully leaving an almost glass smooth surface. The colors are not as vibrant as I would have hoped but nevertheless the wood is quite beautiful to my eye. This little box at 1 7/8" tall and 2 1/2" in diameter has a surprising amount of heft/weight to be mostly empty...Comments appreciated.
Re: Mexican cocobolo beaded box...
Exquisite!!
Ed Moore
>This appears to be extremely well-executed. Since there are lots of places that can't be thin on this piece, it isn't surprising that a dense wood like cocobolo would yield a box with some heft.
Ed
Beautiful... Inspiring... TY!
Carol in Illinois
>Nicely done. Good clean edges and nice shape. A box to be proud of for sure.
I'll share a photo tip. Do you see how the top is light. It is because it is reflecting the white background. What you can do sometimes is put a piece of black paper behind the piece and just high enough to be out of the photo. that will sometimes remove that white reflection and give you good color to the top. Of course sometimes in order to work the paper has to be in the photo, which of course won't work. It's worth a try.
JKJ in East TN
>Very nice! Cocobolo is one of my favorite woods for small things (boxes, tops, goblets, wands). I do have to cover up well or my neck and arms will itch for a week.
I discovered one thing the hard way about about Cocobolo. When making tops I used Watco oil on one of two made from the same piece of wood, then used friction polish (shellac) on both. Over a few months, the one with the oil turned darker and darker until a year or so later it is as black as ebony. The other one retains most of it's beautiful color.
That is a sweeeeet one, Mike!!!
Gil Jones on Lake Seminole GA
Delicious!
Jennifer@Indy.USA
>A stunner Mike.
When and where can I take your class?
I need it bad :)
Jen
john pickett
>en espanol, por favor.
Mike Stafford
Mike Stafford
>John, I love your photo tips. Feel free to critique my photos and offer suggestions any time. I am such a novice photographer I sometimes feel as if I am using a Brownie camera again. I will definitely give that a try. Thank you for the tip because I have been struggling with the problem you describe with a number of my photos.
Thanks again!
Mike Stafford
Mike Stafford
>John, I agree with you on cocobolo turning darker with oils and varnishes. I failed to mention this box is finished only with wax after sanding to 1200 or so....at least until it was smooth...:)
Mike Stafford
Re: Delicious!
Mike Stafford
>I wish you were nearby. I would love to indoctrinate you into box turning. If you haven't guessed, I love turning boxes and I want everyone else to love turning them also.
Thanks a bunch!
Mike Stafford
Mike Stafford
>Yo no hablo Espanol. Es posible que un poquito...
Shoot I am from the South, I barely hablo Ingles.
Re: Beautiful
keith zimmerman, Normal IL
Terry Q
>Another fine example of your excellent work. I also wish you were closer. I could use a few lessons myself.
Terry
Philip Duffy
>Oh soooo purty! BZ. Phil
Mike Stafford
Thanks all!!!
Mike Stafford
Jorge Castaneda
>Mike,
I have a beautiful hand plane made for me 1n 1999, is as beautiful as when new, the fellow that made it just sanded to 600 and buffed with brown paper; it is so oily that really needs no finish.
Jorge
Mike Stafford
Good to know, Jorge...
Mike Stafford
>I will have to give that a try. I will admit that when I used the felt pad on the bare wood before the touch of wax it looked pretty good. Thanks for the suggestion.
Danny Wells
>Beautifully done Mike, as usual. I too love Cocobolo. I'll turn anything out of it, but mostly duck calls and my turkey calls. It makes a great call because it has good tonal qualities.
Danny
RonZ
>Beaautifully done! I'm glad there are a few others that spindle turn, too. What did you use to finish it?
Mike Stafford
Mike Stafford
>Sandpaper and wax...although I learned from Jorge that I might have been as well off just buffing it up real well and leave the wax off...
Mark Kauder, Phenix City, AL
>Very Nice, Mike. Very classy.
Mark
