I am looking to purchase some small hollowing tools for making boxes and ornaments on my mini lathe. I have been experimenting with grinding down Allen wrenches and have not been too happy with the resulting surface not to mention the difficulty in reaching the ?shoulder? area around the opening. I am considering the mini Keltons or the Stotts or one or more of the Hamlet formed scrapers. Any comments or suggestions on these choices or other alternatives will be greatly appreciated.
>I have had the Kelton mini set for about a year and I am very satisfied. I use them for small hollow forms,christmas tree ornaments, etc. You might consider the hunter carbide tool also. I recently purchased the cutter and when used as directed is not as prone to grabbing and catching.
If you decide to buy the kelton set I would recommend making individual wood handels and only buying the cutters.
>Eric I make my own from either drill rod or cold roll steel with a HSS tip silver soldered on. I'll take a photo of the shapes tonight. It will be late because I'm going for a long bike ride after work.
You might also look at the posts below on the tools I made to hold the Hunter cutters. You can make this same shape and not use that cutter. The flat tool I made which has the cutter on the tip is a modified copy of one I made years ago from an old Planer blade. It works extremely well for hollowing under the lip on ornaments. I think I still have a photo of metal I shaped. I'll try to post that as well.
>Eric Here are some of my home made hollowing tools. The one on the left is an allen wrench. The rest are Drill rod except the one with the HSS tip soldered on. You can get away with a small crook on the end but if you need to bend it more to reach really tricky areas you will need to add an extra bend to keep the tip aligned with the shank of the tool. This reduces the amount of twist you feel when cutting with this tool.
>Try to follow up on John Lucas's advice. You can get the drill rod and HSS cutting tips from Enco; get the HSS with 10% carbide. You'll need a mapp gas burner, too. All very affordable and easy to use. And( here I disagree with John, just a little) , I wouldn't worry about having the tip of the tools in line with the axis of the tool shaft to reduce axial torque. It's actually good to have some torque so that when you get a catch, the tool will swing harmlessly down and away from the wood.
>Actually the bend doesn't have anything to do with a catch. On hollowing small things like this a catch is usually because you either take too big of a bite or you were cutting below center. I said cutting but your really scraping.
What reducing the torque is all about is reducing the fatique factor when hollowing by hand. You don't have to grip the tool with a death grip. It also helps you keep the tool at or above the center line. The further the cutter is away from the center line the harder the wood pushes it down. This is the opposite of using cheater bar on a socket wrench. The cheater gives you more leverage. A shorter bar has less leverage.
On smaller tools like this you can easily harden the tip with a propane torch. On 3/8" or bigger you will need a mapp gas. You definitely need a mapp gas to do the silver soldering. I find with drill rod you don't really need to harden the tip but I do anyway so that I don't have to sharpen as often.
>John, Thank you for the info and especially the picture. I think I will have a try at making some drill rod tools. The picture of the allen wrench tool also has me thinking of what can be done with them as I hadn't thought of bending the longer leg to provide better access. Guess it will be off to the hardware store this afternoon.
I will post pictures when I get the tools made. I was already following your post on your new designs for holding the Hunter cutters - truly amazing work. The formed/hooked scrapers I was looking at are somewhat similar in shape.
