Re: Blackened lathe ways: how to clean?
Rick Allen
>Wax will protect the lathe bed from reacting with the tannin in Oak and Cherry. If you turn a lot of that wood wet you will likely reapply wax to the bed a few times. Wax also make adjusting the banjo a dream.
I have used motor oil to clean off the lathe bed. It must be the detergents found in many motor oils that did the work. Or maybe it was the paper towel I applied the oil with.
I don't like to leave a lose piece of cloth or canvas on the ways when wood is spinning. I worry that the cloth will get "involved" in the process. I don't want to get flailed by the "cat-o-9-tails" that the cloth might become. I could attach the cloth but then my movement of the banjo is inhibited.
