Teak oil?
Teak oil?
Teak oil?
Carol in Illinois
>Hey, gang, do any of you use Teak Oil on turnings?
I ran across some in a marine shop, obviously meant for care and feeding of boatwood. I keep searching for yet another experiment, and wondered if y'all had tried this. How is Teak Oil different from, for example, Tung Oil?
TIA
Carol
Re: Teak oil?
Re: Teak oil?
RonZ
>If I'm not mistakened, teak absorbs the oil and needs to be replenished when the oil dries up, usually for inside use. Tung oil and its derivitives develop a build that seals off the wood.
Re: Teak oil?
Re: Teak oil?
Brian Hahn in SW Wisconsin
>Teak oil usually contains tung oil.
Re: Teak oil?
George Balock
Re: Teak oil?
George Balock
>Carol,
I've used teak oil with good results on exotics. It doesn't yellow and darken as much as Watco or Waterlox. Here is a pic of a cocbolo box finished with teak oil and buffed.
George
Re: Teak oil?
Re: Teak oil?
John Veerkamp
>I have used teak oil on some turnings. It is thinner than most "tung oil" mixes. It is usually a mixture that contains uv inhibitors and designed for exposed surfaces like boats and decks. It doesn't build much, but seems to work well for popping grain.
John
Re: Teak oil?
Re: Teak oil?
Russ Fairfield
>Teak Oil can be many things, but it is essentially no different from any other oil finish except it is packaged in a different can with a higher price. Some manufacturers add some color to their Teak Oil to compensate for the bleaching of the wood from exposure to salt air and sunlight, and some might add a UV agent.
Re: Teak oil?
Re: Teak oil?
Wally Dickerman in Arizona
>Back in my boating days I had a boat that had lots of teak. Decks, rails, trim and more. I've applied gallons of Daly's SeaFin teak oil. At least once a year to all of it. It's actually tung oil plus UV, plus more. Meant for outdoor use. I wouldn't use it on a bowl or vessel, although you could.
I made sure that my next, and last, boat had fiberglass decks. It did have teak rails and trim, but I used top grade marine varnish instead of oil. Still had to apply a couple of coats once a year. It was a 45 footer so there was still quite a bit of teak. When I retired we sold our house and lived on it for awhile. Cruised between Puget Sound and Alaska every summer. (No, I didn't have a lathe aboard)
Wally
Re: Teak oil?
Thanks all. Will proceed w/ experiment!
Carol in Illinois
