Coolest Surface Decoration Tool! Laser! *LINK*
Craig Daymon
>There was a link on Slashdot today to an article (video and article) on how to turn a Mini Mag Lite into a burning laser. It uses the laser diode from a DVD burner. Should be a pretty controlable surface decoration tool.
Just don't let the kids get a hold of it. This IS more dangerous than pointing a laser pointer at someone. You might consider protective glasses when using it.
Here's the link.
-Craig
Mini Mag Burning Laser
Re: Coolest Surface Decoration Tool! Laser! *LINK*
JKJ in East TN
>Craig,
Your link doesn't work, but regardless, be very, very careful. "Consider protective glasses" seems like an understatement to me. I've worked in a laser lab and know people who have slashes missing from their vision, annoying "floaters" that will be there for every waking moment the rest of their lives. The laser light that can burn is generally invisible. All it takes is one accidental brief movement of something reflective (such as jewelry or dropping a tool) through the beam to instantly and permanently damage vision. Protective goggles (not glasses) are a necessity around powerful lasers. (BTW, the blink reflex is one reason bright visible light lasers are not as dangerous to eyes compared to invisible light lasers of the same power - if you can't see it you certainly won't blink.)
I don't know what frequency (color) is used in a DVD burner, but be aware that the filter in protective goggles must match the frequency of the specific laser light in use.
The safest way to use a powerful laser in the shop is to construct a case or box to completely shield the user. Interlocks cut power to the beam if the box is opened. This is how laser engravers are made (the last time I checked).
Re: Fixed link...
JKJ in East TN
>>I'm one of those who have to live with a few "floaters"
>in my vision (probably from welding flash).
Yikes, I didn't know that welding light can damage the retina like laser light. I asked my eye surgeon once about that and he said the uv from welding light can burn the cornea but would (should?) not create any permanent damage. Cornea burns feel dry and scratchy but heal in a day or so.
Are they significant floaters? (Large missing straight or jagged streaks or blobs?) I read once that almost everyone has small floaters that look like dust or strands, but understood they were due to biological causes such as clumps of junk floating in the fluid in the eye.
BTW, I very occasionally get some amazing temporary floaters accompaning a severe migraine headache. Mine look like a jumbled mass of short straight bright lines in the center of my vision making focusing on anything impossible for a time. These lines slowly disperse outward until they fade at the edge of my vision. Built in light show, yippie. Not a good time to drive a car or fly a plane.
Re: Fixed link...
Bill Howatt
>My wife has floaters and has never been a welder! It apparently is caused by changes in the fluid in the eye - some of it isn't as transparent as it should be and these "pieces" float around.
Bill
Re: Fixed link...
Peter Teubel
>"Are they significant floaters? (Large missing straight or jagged streaks or blobs?) I read once that almost everyone has small floaters that look like dust or strands, but understood they were due to biological causes such as clumps of junk floating in the fluid in the eye."
No, nothing big. You described them perfectly. Perhaps mine are normal after all.
Steven Antonucci
Very cool, but...
steve antonucci
>I noticed that the laser didn't scribe the wall behind the two target items. I wonder if there is a power loss beyond a few inches?
Would have been awesome if the guy burned through the wall behind the match. I'd be making one now if it did...
Steve
Re: Very cool, but...
>"Send a signal to Star Fleet, it has a range limitation." Capt. Kirk
Vision Migraines
Ray Thompson - Middletown,IN
>At least that is what my eye doctor calls them. They are usually precursers to a migraine headache. I get the vision migraines but never have the headaches, weird. About half the time they are triggered by a flash of reflected light like the sun off a windshield or the hood of a car.
Ray
Ken Grunke from SW WI
>I'd think a good way to apply this idea is to have the diode on a printer mechanism, hooked up to a computer, under a protective cover so there's no chance of injury. Voila, a laser engraver!
Re: Fixed link...
Roger Smith
>I have several visits to a retina specialist in the last 3 months for floaters. According to him there are two major causes of floaters. One type is caused by a tearing or detaching retina. This is usually accompanied by flashs of light as the retina is tearing. Pieces of the retina tear away and float in the fluid of the eye. This is very serious and you should find the best specialist in your area.
The other major type is caused by a rupture of a blood vessel in the eye. The blood enters suspends in the fuild of the eye. This type is not as servere. The blood will dissolve over time and be cleanse from the fluid. However, a person with this condition stills need to consult a specialist. First to insure that it did not come from a torn retina. Also, was there some other factor that caused the rupture such as high blood pressure, stress or a minor stroke.
I have had both and both types make you take notice. You may have two eyes, but I would like to retain good vision in both.
JKJ in East TN
>Looking at the link and some associated links, it seems that the laser diodes salvaged from DVD players are around 650nm, well in the visible light range. The power seems to be way too low to scribe wood.
One person wrote that he felt a stinging on his arm after holding the laser beam in one spot for two seconds. In order to scribe wood in a reasonable time, I suspect you would need something powerful enough to seriously burn your arm in way less than two seconds. There's a big difference in the energy needed to pop a black balloon and burn a mark into light-colored wood. I have a hard time imagining this type of laser could be made to work.
BTW, we did a project at one time for Coors Ceramics. They had a bank of huge lasers (carbon dioxide, a type commonly used in science and industry) powerful enough to burn holes through and cut shapes out of ceramic plates. If I remember correctly, the housing for each laser was several ft wide, perhaps 5-6 ft high, and as long as a car.
Craig Daymon
>So not quite hand-held. Hmmm...
There are special glasses available for working with lasers. We have some here at work for working with mercury arc lamps that might provide the protection needed. I'll have to ask.
I would imagine the same design could be applied to a stronger laser or enhanced with a different power source. Ideally you would want a button that would turn off when pressure was not applied, not just a simple On/Off switch.
Well, maybe we can just wait for Ken to finish his engraver plans.
-Craig
P.S. Ken, don't forget that we want to engrave circular objects, not just flatwork.
