Tool Handles
Tool Handles
Tool Handles
Mike fromTn.
>OK! Finally decided to turn some new handles. Let me hear some ideas. Lenght, Dia., Material? I've got some cherry, some walnut or should I go with some red oak? I turn in the 10" to 16" range if that helps. Anybody got a site for proper tool mounting into the handle?
Re: Tool Handles
Re: Tool Handles *LINK*
Brian Hahn in SW Wisconsin
>Several years ago Alan Lacer had a good article in American Woodturner. The article is on his website at the link below. Click on articles and it is at the bottom of the list.
Alan Lacer Woodturning
Re: Tool Handles
Re: Tool Handles
Ken Grunke from SW WI
>Make each one different, of a different wood and/or shape. Makes it easier to identify a tool out of a pile (or neatly organized rack) of them.
Re: Tool Handles
Re: Tool Handles
RonZ
>I make my own and Ken is correct. For instance, make your skews out of walnut and have a different length and identifier for each size, etc. It's fun and you can turn with extra pride.
Re: Tool Handles
Re: Tool Handles
Jorge Castaneda
>Mike. here is a picture of how I make mine, using a short lenght of galvanized pipe:
http://www.woodcentral.com/cgi-bin/turning.pl?noframes;read=155818
Hopr it helps
Jorge
Re: Tool Handles
Link  *LINK*
Jorge Castaneda
Handles
Re: Tool Handles
Re: Tool Handles
Fog Tanner
>I make all my tool handles. They are made from mainly Ash, Pecan,or Red Oak - mainly Ash becuase it is cheapest in my part of the world. Cherry and Walnut would be good too, I die some of my Ash handles walnut. On skews I make the end more or less flat, on the gouges and scrapers, I round then over to be able to tell the difference. All have been the traditional "coke bottle" shape, and sized to fit my hand.
I have started using brass threded inserts to hold the tools in after using my Kelton handle, that came with my McNaughton coring tool, for my 5/8" Thompson. I have both a handle for my Thompson skews and another for 1/2" gouges that use the set screws. I am working on one for 5/8" gouges now. Its drilled from both ends to accept lead shot. This one is basicly straight, partially because of being drilled from both ends and not wanting a weak handle.
Without the setscrews, my other handles are dilled a few thousnads under the tool diameter and the tool is an interfearence fit. I did have a couple of couges that were undersize and used 30min epoxy to hold them in.But, I like the idea of removing the steel for sharpening, especially a bowl gouge with a long handle.
Re: Tool Handles
Re: Tool Handles
JKJ in East TN
>>...mainly Ash becuase it is cheapest in my part of
>the world. Cherry and Walnut would be good too..
Where is your part of the world? I can't find any ash at good prices. I'd gladly trade cherry and walnut for ash, green or dry.
Re: Tool Handles
Re: Tool Handles
Fog Tanner
>I live in the Houston area. I buy kiln dried unmilled Ash for some of the projects I do and have had some pieces that were big enough for tool handles. Then they started having pieces that were 8/4-9/4 square by 8' so I started buying those for handles. Last one I bought (8/4x8') was $9 something after tax, seemed like a good price for what I got. Have also bought some Pecan the same way just to have a differnt wood for a change.
Re: Tool Handles
Re: Tool Handles
Chuck Engstrom
>I've made a couple of handles out of cherry and ash, and used copper tubing compression fittings for holding the tool itself (see photo). I had to split the compression ring to allow for variability of tool sizes, and drill out the lower part of them in some cases, but they do work nicely for double-ended tools etc. I can change tools in a few seconds without needing a wrench or hex key to do it, and these don't mar the tool surface at all. I put lead shot in the bottom end of them.
After making several of them I found that some had a more comfortable heft than others, but of course I hadn't recorded any measurements of lead shot cavity, etc, which would let me repeat the design. Solution: I got my local orthopedist to x-ray them for me. Lead shot shows perfectly, of course, and the hollow parts of the wood show up OK as well. "You'd be amazed at what people have brought in for us to x-ray," he told me.
Best--
Chuck Engstrom
Re: Tool Handles
Re: Tool Handles
JKJ in East TN
Ha, I can second that! I worked for years as a radiographer dealing mostly with industrial piping in the field (with gamma sources) but also shooting a wide variety of things in the shop with x-ray machines. People who worked there were always wanting something x-rayed "after work" (and for free, of course).
