Somewhat turning related:making curl pop!
Steven Antonucci
steve antonucci
>I just finished a curly maple bowl, and as usual, I am disappointed in the "pop" I got from a really curly piece of maple. I was using a broken up, busted stump when I noticed it was ridiculously curly. Brought it home, roughed and DNA soaked, and finish turned (to 600 Grit).
So I hit it with some lacquer, and nothing. If I hold it right, I can see that there's curl there, but I want to have that "wow" curl pop I see in other's work.
How does one get that?
Steve
Re: Somewhat turning related:making curl pop!
Re: A base coat of oil usually ....
Jamie Donaldson
>... pops it best for me-Fine Woodworking did a story about this subject recently. On lighter wood the oil finishes will yellow more than I sometimes like, but a light application of Waterlox is my usual method, and often the final finish as well on many of my pieces..
Troy German
>I've had good luck with tung oil. Shellac also works well.
Troy
Carole Valentine
>Jamie, on light wood, if you first use a wash of thinned lacquer (50/50) and wipe it dry then apply the Waterlox the wood will not yellow much at all.
RonZ
>I use what Troy uses and it does the trick, especially with Mylands wood finishing oil. I also learned not to sand more than 400 as the finish will no longer soak in the grain at a higher number. Once you build a good thick finish, then you can Beal buff.
The carob bowl is not a good example for curly but it gives you the idea of the chatoyancy you can get without too much yellowing.
Jorge Castaneda
>Steve,
A very thin coat of a dye like burnt umber diluted in alcohol followed by sanding, will help you pop that grain, you may need to do it a couple times, some of the dye will be removed when sanding, some will remain, that is what makes it pop.
Follow with a 50% coat of tung oil, finish with another of undiluted tung.
I used to do this in table tops, have not tried in a turning.
Of course some change of color will occur, then again you can use any color you want.
$0,02
Jorge
Brodie Brickey
>Steve,
The piece below is Watco Danish Oil Medium Walnut applied and allowed to sit for 15-20 minutes. Then wipe off excess. Wipe on poly final finish. Sanded to 400. Wood is maple & Ash.
Regards,
Brodie
Steven Antonucci
Thanks all
steve antonucci
>I wanted to add some more parameters to what I was trying to achieve- since the advice here has all been good, but just missing one bit.
I know I could use dye or oil to pop the curl, but I really wanted to have a "natural" maple color- almost white. Oil finish is too yellow in my experience, and I'm looking for the best way to have my cake and eat it too. I've seen it, so I know it can be done. Just not sure how...
Steve
Re: Thanks all
Jorge Castaneda
>Steve,
You could try the 2 part bleach and then Mark Kauder's system,
It will be very white and very bright...
