my sander bit the dust
another autograph
>Hello: I have a Milwaukee close quarter drill that I have used only for sanding. I have had it for about a year and bought it as a factory reconditioned unit. Yesterday it started acting up a little. The variable speed trigger would not let the drill start out at a slow speed but was either off or running about 3/4 speed. So today, I was trying to finish up a sanding a bowl. I used the drill, and then laid it down on the bed of my lathe. It about a minute it started running on its own, ran for about 5 seconds and right when I picked it up a lot of smoke came out of it and actual flames came out the back motor vents. The case was very hot, almost too hot to touch. I am just thankful it happened when I was close to it and that it didnt fall into the dry shavings under the lathe and start them on fire. Now I just have to see if the warranty is any good. Anyone else ever have something like that happen? Jared
Re: my sander bit the dust
jared
>My name is supposed to read Jared and not another autograph. Dont know how that happened.
Re: Sounds like you will be........
Jamie Donaldson
>....buying another drill soon Jared. I've never had one flame out as you discribed, but have killed them on a variety of other ways. I don't believe you will have much luck pursuing a warranty claim- a repair facility told me that sanding voids any warranty. I've been able to keep 2 out of the 3 I own running by doing some repairs, but blowing out the dust daily has been the best way to keep them operational.
robo hippy
>I have 4 of them. In general, they last me about 6 months. Ususally the bearings go out. There are 6 bearings, in 4 different sizes. I have also worn out 2 of the plastic casings that the drills are in. I have never had one flame out. Could be the trigger, or possibly the bearings. I would take it to a local tool repair shop (I suppose I could learn to do it by myself, but I would rather leave that task to a professional) and ask them. New drill is about $125 (the cheapest I have seen)at Coastal Tool.
robo hippy
Jared, the bearings are supported in plastic...
TDaniel
>so if they get hot they melt the plastic which is the case. Since you said that you purchased it on ebay I must ask, "Did you get the one with the fwd/rev switch on the top or on the rear?" The one with the paddle type switch on the rear is the old style and parts are no longer available for it. On these drills it is very important to replace the rear bearing when you first hear a noise; if you wait then you will also have to buy a case which basically means you have bought a new drill.
>I know this runs against the grain here but I've been using a regular Dewalt straight drill for sanding. It cost about $60 when I got it new. I've been using it for about 4 years now and it's holding up strong. It does take 2 hands to hold it but I find I have more control this way and it's actually less tiring than trying to hold a drill by one hand. I keep looking at the angled drills but they are twice as expensive as mine and apparently don't last as long.
Norm Smith in Nova Scotia
>I buy the cheap angle drills on EBay and throw them away when they quit. I go through one in about a year or so. The last one I purchased locally for $38.00 Canadian.
Me too John
Dave Peebles Lyons, Ohio!
>I have a Dewalt drill that is going on at least 7 or 8 years. I really never got the right angle drill thing. But that didn't stop me from buying one. :) It has been hanging on a hook on the wall for years. I used it a few times and put it to one side. Maybe it is the shape of the bowls I turn... more open type, but with all the problems I hear about the right angle drills I think I will stick with my old Dewalt.
P.S. I have a fine Sioux right angle drill motor for sale... but on second thought, I guess I will keep it for drilling through 2x4 studs for any future electrical additions. :)
Dave
Me Too...
>I have a Dewalt drill that must be fifteen or twenty years old and for the last six or eight years I have been using it as my sanding drill, because I hate it and was trying to kill it. It won't die. Once in a while I pick it up from among the crud surrounding the lathe and start sanding. It blows sawdust and whatever out into the palm of my had and it stings. Just adds to the hatred for the drill and enhances it's evil reputation. You'd think I'd learn to blow it out, but I am hoping it will die so I can get a new one that will have my affection.
I had not thought about the one hand verses two hands thing. Hmmm! I may not need an angle drill after all. Especially after all the threads here about them dieing an early death.
Possible cause....
TDaniel
>For some reason there were a lot of "bargain priced" Milwaukee drills on ebay for a while. I noticed that one that I took apart had bearings that were "made in China". I am wondering if Milwaukee knew they had made a big mistake by using these bearings and decided to unload them on ebay?
Re: Possible cause....
jared
>TD: I bought his drill on ebay from what was supposed to be an authorized Milwaukee dealer. I have the receipt and a card that went with it that says it is covered under the regular warranty. It was only used a year and not that heavily. I regularly blew the dust out of it, daily as a matter of fact. I used a regular makita 3/8 drill this morning to finish a bowl up and it worked just fine too, I guess it is all in what you get used to.
I am going to mail it off to the local Milwaukee service center today. I talked to them on the phone and they said they would take care of it. Jared
Steve Russell
>Hello Jared,
I've burned up several electrical drills by using them for sanding... These ranged from el-cheapo units to ones that cost several hundred dollars each. I gave up on electrical drills altogether and switched to pneumatic drills for all sanding on the lathe. Not only are they smaller and easier to handle, they run cooler than an electric drill when used for extended periods of time.
I have five different pneumatic drills that I use for sanding and a few dedicated sanders that are used on larger turnings. I have never burned out a pneumatic drill, even the el-cheapo $40.00 one is still going strong after eight years of heavy production use... :-) I hope you can get satisfaction with your burned out drill from the manufacturer and I'm glad it did not cause any more damage to your shop. Take care and best wishes to you and yours!
Steve Russell
EWW, WVP
The Woodlands, Texas
Steve, what kind of...
Clem Wixted, Jonesboro, AR
>...air compressor do you have?
Clem
>I really want to go pneumatic but the cost of the compressor is just too great at this time. I do have a sander and use it occasionally but only for very short periods of time because my compressor runs constantly.
Re: Steve, what kind of...
Steve Russell
>Hello Clem,
I have a Coleman Industrial Compressor, 5HP with an 80 gallon upright tank. I do not recall the CFM delivery rates, but I can look if you need them as well. I really like the pneumatic drills and dedicated sanders. If you look at most industrial manufacturing companies that use drills and sanders, they use pneumatics not electrics. That's good enough for me...:-)
Steve Russell
EWW, WVP
Steve Russell
>Hello John,
I was lucky in that I already had an industrial air compressor, so switching to pneumatics was easy. Had I not already had the compressor, I would have stayed with electrics probably. I really like the small pistol grip pneumatic drills for sanding as they allow you to have access in very tight areas. I've been using small palm grip ROS on the exterior of larger pieces and the quality of the sanded surface is amazing!
I also have some pistol type ROS that work well on interior and exterior applications. For me, with all of the production work I do, pneumatics is the only way to go... I just wish I had switched before I burned up five electric drills... :-o Take care and best wishes to you and yours!
Steve Russell
EWW, WVP, EWWFS
Stuart Johnson
>I have a Grex ROS and run it until the compressor kicks on then use it as a passive sander until the cycle stops. I would like to purchase a larger compressor but can't justify it right now.
