Shop shots, where do you lathe from...>>
RonZ
>..>>I hope to be moving to a larger shop soon and I thought I'd take a few pictures of the old shop. I've been so busy, I just never had a chance to. What does yours look like?
My lathes are in their fourth year and going strong, I hope they provide me with many more years of service.
My old faithful Vic
Then there is Vickey the work horse, she had to have the controller changed.
My sharpening station
and my drill press and Tormek.
Re: Shop shots, where do you lathe from...>>
Norm Smith in Nova Scotia
>Ron, nice setup. How do you keep it so clean?
Norm
Allen Neighbors
>Good looking shop, Ron. What's the make of the white grinder?
I see you have both of your lathes against the wall. I often wonder what it would be like if I had learned to turn from only one side of my lathe. Do you ever wish you could get on the other side for some cuts?
tm
>Nice shop... but my curiousity won't leave it alone.
Whats the purplish fluid in the erlenmeyer flask?
RonZ
>Its a spray bottle and its denature alcohol. I spray it on wood before I'm going to dye with alcohol based aniline dyes.
RonZ
>Thanks Allen. The white grinder is sold in the US by Garret Wade. Its a Taiwanese slow grinder and I'm really happy with it.
Both my lathes are agaisnst the wall because for now, space is a premium. The lathe I teach on [not shown] is not against the wall. I'm thinking about maybe changing one of my lathes in the new shop. Most of my work is spindle so the wall is not a major issue. I don't know the ratio for needing to turn on the other side vs having all my tools in front of me and easy to grasp. Now if you used the argument about a tool falling behind the darn lathe....
RonZ
>Thanks Norm. First you don't show the floor. =o)
The area is small so instead of brushing off the lathes, I vacuum, usally between turning and finishing. I especially vacuum a lot now [that's why its clean] because I have a project comissioned in paduak. While the wood is beautiful....
Magnetic tools
JKJ in East TN
>I tried hanging a skew from a magnet once. It became magnetized and interfered with sliding along the toolrest until I demagnetized it. Do you have any problems with this?
Re: Magnetic tools
Russ Fairfield
>YES, steel becomes magnetized in the presence of a magnetic field. Magnetized tools stick to steel and cast iron tool rests.
Magnetized tols are also difficult to sharpen because all of the metal particles thatare removed by the grinder will stick to the tool.
Some folks argue that they have no problem with magnetic tool racks. I don't understand how they can avoid a basic law of physics. Maybe they are using a non-magnetic stainless steel for their tool rest.
I teach the woodturning classes at a Woodcraft store. All of the tools are held on a magnetic rack against the wall. All of the tools become magnetized from one week to the next. One of those little degaussers (demagnetizers) has become a necessity. There are a couple large roughing gouges that won't fit through the opening in the degausser, and they have becomes so magnetic they are no longer useable.
Re: I understand the physics ......
Jamie Donaldson
>... in theory Russ, but I have a magnetic tool(knife rack) holder beside 2 lathes for many years and have never had any evidence of magnetized tools becoming a problem? There are no grinder slivers attached when I sharpen, no tool/rest attractions when working, nothing! Both of the knife racks used are quite old- maybe the strength or type of magnet makes the difference? I had to be very aware of such complications during my camera repair business days,and still use the degaussing coil on my tiny tools on occasion.
JKJ in East TN
The difference may be in the application of the field. If the magnet presents both north and south poles so the tool closes the flux loop (by far the strongest way to grip something), then I can see how pulling the tool straight off the holder may not magnetize it significantly. Sliding it off would likely magnetize it more. ("Wiping" one pole of a permenant magnet down a steel rod, such as a screwdriver, is a good way to magnetize it.)
I have not tried attaching tools to a commercial magnetic tool rack so I wondered how that worked.
In my case, I attached the tool near the end to one pole a very powerful rare-earth magnet stuck to a steel surface and after a few uses the tool was magnetized enough to stick to the tool rest. It did give me a problem with filings while sharpening.
RonZ
>I don't know about y'all but 1. I don't have any problems with magnetizing or grinding. 2. If I did, it might help my students when I keep telling them 'first make sure the tools is on the tool rest and THEN aproach the wood.' =o)
If it makes a difference, the magnetic racks are from Ikea.
