Chainsaw sharpening
Chainsaw sharpening
Chainsaw sharpening
TDaniel
>Whatever method that you use to sharpen a chainsaw chain there are 2 very important things to remember:
1) You must know what you want the tooth to look like when you finish. Unless you know this you are wasting your time.
2) The cutting edge is furthest from the bar. Many people push down on the file and effectively are only sharpening the gullet of the tooth. You must lift the file on the last couple of strokes to sharpen the cutting edge of the tooth. The underside of the top of the tooth is what needs sharpening.
You want the finished tooth to look like the letter "C" from the side. If you raise the file handle too high you will remove the corner of the tooth. The corner is the most important part of the tooth as it starts the cut. After the corner starts the cut the top edge of the tooth peels the chip out. The drags are important too but be careful not to take too much off them because that may make the chain very grabby, causing kick-back.
Re: Chainsaw sharpening
Excellent post TD
Re: TD's comments really ........
Jamie Donaldson
>.. emphasize why the proper sized file or stone is critical to properly sharpening the cutting portion of the chain teeth. Being close is not even close!
Edge angle
Ken Grunke from SW WI
>Good points, TD. It's very important to spend some time setting the proper height of the file or cutting stone, as a very small change in that makes for a more drastic change in the angle of the cutting edge. Would you agree that about 45 degrees is pretty good for that angle,which is about what C is below?
The edge on A is obviously too thin, where the stone or file is too low-- and it's too high at B, giving a blunt edge which in my opinion, is the lesser of the two evils. B will still cut, and the edge will last longer but it will make the saw work harder.
With this in mind, I find it hard to believe how anyone can think they can sharpen a chain freehand, without a guide holding the file or the grinder.
Re: Equal Treatment For All
>In addition, Ken, filing gives no control over the size of the cutter. When I sharpen my chains (Tecomec grinder), I mic each link on each side of the chain to find the shortest (front-to-back) tooth at the outside point. I then set my stop and clamp to that length and grind all teeth to exactly that length. What I get is a precisely balanced chain that cuts laser straight and smooth because all cutters on either side are taking the exact same bite in the wood. You cannot do that with a file. When I go out cuttin, I take 3 chains for each saw. If one goes dull or starts to wander left or right, it's off and into the resharpening bag, and a fresh chain goes on the saw.
mm
Re:You guys are ruining a .....
Jamie Donaldson
>.. good redneck hobby with all this scientific measurin' mumbo jumbo! Us'ins use a chainsaw for cuttin' trees, not a sharpenin' contest with rules!!! ;-)))
Re: Edge angle
TDaniel
>Ken, once you have it in your mind exactly how you want the cutting link to look after sharpening then everything else is downhill. For many sawyers the little Husky roller jig can really help and I do recommend it but I frequently sharpen completely freehand with just the file. I sometimes change my edge angle if I intend to cut mostly pine. A little experimenting with different angles would be good for anyone to try. In other words folks...don't take our word for it...try a little sharper or a little more blunt face edge and see what happens. A lot depends on the power of your saw. My technique for hand-filing is too apply downward pressure at about 7 o'clock for the first 2 strokes, then apply pressure toward 9 o'clock for 2 stokes, and then light pressure toward 11 0'clock for the final 2 strokes. (Reverse for the other side of the chain) Look very closely at the tooth after sharpening one and if it is what you want the tooth to look like then proceed; if not, then make an adjustment.
If you like to hear yourself talk....
TDaniel
>you should speak more plainly.
Russ Fairfield
>I have always thought that a 110-volt bench-top chain grinder was a good investment. With the cost of chains and $7 to $10 to have one of them commercial sharpened, it doesn't take very long to justify the $300-400 purchase price if we do any amount of cutting. Besides that, it is a good excuse to buy another tool.
Something that those who grind and file on the saw never think about is the grit and filings that get in the bar groove. There is nothing that will wear out a bar or chain faster. Filing or grinding off the saw is always better, and the chain should be thoroughly washed in a cleaning solvent and dippen in oil before it is ready to be put back on the saw.
But that there's good talkin"
Keith Tompkins
Keith tompkins
>A few more suggestions for hand-filing a chain.
1. a file cuts only on the push stroke; ease up on the pressure on the return stroke. Use as much of the entire length of the file as possible.
2. Tighten the chain before attempting to hand file. A loose chain is extremely difficult to sharpen properly.
3. If necessary, place a piece of cardboard under the saw. Draw the proper angle on it with black marker as a guideline.
4. Give each tooth the same number of strokes. If I have a few damaged links, I don't worry about it. They'll catch up eventually.
5.Don't run the chain into the ground!
6. Sharpen the chain with each use, and loosen the chain while in storage to prevent bearing damage.
Betterin Tungs
Steven Antonucci
I'll tellya whut!
steve antonucci
50%
TDaniel
>Russ, I agree with you that grinding a chain while on the saw will leave abrasives in the bar but I must respectfully disagree with any substantial effect by filing while on the saw. My old Husky 61 is now 13 years old and has had many sharpenings while the chain was on the saw, literally hundreds, and the original bar is still good. During 11 years of this time I owned a portable sawmill so my chainsaw has seen very heavy use, much more than most would use theirs. My thought is that when filing, most of the filings are falling beyond the bar, not into it. If using a Dremel and stone then I think you are absolutely correct, the grit and filings are getting into the bar.
JKJ in East TN
I've never bought or tried one, but a guy told me once he would run his saw with a carbide-tipped chain right down into the dirt in an arc to cut tree roots! Yikes.
Nah.
>The term's either "So, like, ah, yougottaproblum witdat?" or
"I'm gonna rememberdat, but not like youzwill."
