Turning Apple wood
Turning Apple wood
Turning Apple wood
Bob Rogne
>I need help. I have a number of pieces of Apple to turn , some of which will go to our new library for display and auction.
PROBLEM.. I have turmed three hollow forms (7x5 inch)and they all split by the time I get the to 1/8 to 3/16 in.
What do I have to do. Turn thick and seak, put in paper bag, or soak in DNA.
Help is needed.
Bob R WestMak Turnings
PS I have lots of wood but no time.
Re: Turning Apple wood
Dave Belser
>Apple is notoriously prone to splitting and cracking. If it is drying and splitting while you turn use a spray bottle and keep soaking it while you work. I find wet sanding green wood to be much easier than dry anyway. Once finished do as much as you can to slow down and even out the drying - just putting it in a paper bag and checking it should do the trick. You can use a cheap digital kitchen scale to keep track of the weight.
You didn't say how much of a hurry you are in, it's going to take some time but you should be able to go from green to dry on a thin piece in a week or two without cracking.
Others may have better suggestions.
Good luck and let us know how it turns out.
- Dave
Rick Allen
>The paper bag works. Another method along that same line is plastic bag and paper towel.
Put the wet turning in a plastic bag along with a paper towel or two. Each day turn the plastic bag inside out and put in a dry paper towel. Hang the wet paper towels to dry for use the next day.
Soon you will find that the paper towels aren't as wet as they once were. When the paper towels are mostly dry after a day switch to a paper bag.
I think the color, depth and swirls of figure you often find in apple is unlike any other wood. Absolutely worth your effort!
Carole Valentine
>Apple can be a bear. It is one of the few woods I boil, the other being pear. After boiling I use Dave Smith's alcohol treatment.
Bob Rogne
>Thanks all.
Will try all ways. I have about 6 weeks to have them finished.
Thanks again.
Bob WestMac Turnings
