>I use my Dremel tool, because everywhere I took it for sharpening ruined the chain. Walmart sells the Chainsaw sharpening stone in two sizes. That's what I buy. Never without a sharp chain, now.
>>How do all of you sharpen your nastied up blades
There has been discussion on this in the past - you might find some good stuff in the archives.
I personally file by hand. With a bit of instruction and practice, it is very quick and effective. The most important thing is to keep file in the correct position. Stihl chains and probably others have an alignment mark on each tooth.
However, if the teeth are damaged severely (i.e., chips out of the points after I run into barbed wire or rock) sharpening by hand can take a while. For a horribly nasty blade I use a stone in a hand-held dremel rotary tool. All the chain saw places, hardware stores, and big box stores should carry these little stones.
BTW, I keep far away from the chain saw sharpening people. Many don't know what they are doing, but even so, they will usually set up their machines to grind each tooth down to match the worst tooth. If you have one tooth with a big chip, you will end up with all the teeth nearly ground away. A chain will work just fine if some of the teeth are ground far more than others - this may be constary to some advice, but the pro tree people I know all sharpen this way.
>phil I had the same disaster. Took my saw to the local high end chainsaw shop for a tune up and blade sharpening. The tune up was great, he sharpened the chain by hand with no guides. It cut horribly. I have been using a roller guide that Husky sells at lowes and sharpening by hand with this. It works great.
>...with auto-feed attachment. Got it on Craig's List locally for $100 (gloat). The auto feed is a bit finicky, but once dialed in, I can plow thru many loops quickly. Really handy for 114 link chains!
For my small chains (.043 ga), I will file file them a couple times then discard them, since they are relatively inexpensive. They're too small for the grinder (takes off 1/2 the tooth).
>I must have done something wrong when I used the dremel type sharpening, but I was never happy with the results. Those small diameter stones glaze soooo quickly. It was tough for me keep them cutting. They have some diamond stones now that probably work pretty well. I bought the equivalent of the Oregon 511 from Bailey's. It doesn't seem to make sense spending $200 to sharpen chain when the hardware store charges $4 each, but I sure do like it! Always having dead sharp chain really puts a smile on your face. It's my opinion that the hardware store guys do a good job, but they don't seem to take the time to file down the rakers. If you file down the rakers after a few sharpenings, it will cut like new. If you spend the money to get a fair grinder versus the cheapo's at Harbor Freight, you can also modify your own chain for ripping as well.
>I'll NEVER go back to my local Stihl dealer for sharpening. He took the teeth down to nubs and it wouldn't cut butter. I do my own sharpening now freehand with a file and my chains always cut like new. The key is not to let them get really dull in the first place. Of course, I have not run into any nails or rocks (yet) either.
>I too love the Husky guide sold by Lowe's, but I have some chains in the Stihl green series (reduced kick back design) which won't allow the guide to seat properly on the chain. All the yellow series, full chisel chains accept the guide nicely. The guide is well worth the money.
>I agree Carole, I have been taking my blades to a lawnmower shop and they did a good job...for 5 bucks a blade! I just bought a new poulan classic that came with a file mounted in a guide. We cut down a red oak and went through 5 blades, with the new saw I tried the file, first dousing it with oil, then a couple strokes each on the teeth, maybe 3 minutes. Anybody want to buy some like new 18" blades?
>After several years, and watching a few people who know how to sharpen their chains, I am getting the hang of it. They may chuckle a bit, but at least they don't laugh out loud. If you buy the files, and cut a lot, get them by the box rather than a few at a time. A lot of chains have a line type of guide on them, and that helps keep the angle consistant. If you don't do this, the cuts won't go straight. Also, if you sharpen some teeth too much, this can also cause the cuts to go crooked. If your cuts are curving, this can also cause uneven wear on the bar, further complicating the curving. Sharpening is a push, not a pull, and you push towards the outside, not towards the center. Also, angle it up slightly, about 5 degrees. It takes practice, but mine do cut a lot better after I sharpen them than they do before I sharpen. I do keep several chains for each saw, and a couple of worn ones if I am cutting something that has metal or rocks, or other wierd stuff in it.
>Phil, I have two powered grinders. One is an Italian made Little Nick I bought from Harbor Freight, but which does not seem to be available anymore, and the other is a grinder I bought from Bailey's (also Italian made) that clamps to the bar and runs off the truck battery. I can do the hand file thing, but most of the time, I manage to hit something in or on the log, and the grinders do it a lot faster for me in the shop or in the field. Both grinders do a very good job, and when set up properly will take off very little metal.
>How does one modify a chain for ripping? I have heard that chains made specifically for are available but are expensive and of course there's all the hassle of changing back and forth.
>On the topic of chain sharpeners, I bought my chain grinder at Baileys, think it was $149, best money I ever spent.
Typical chainsaw teeth for cross-cutting are ground at 25-30 degrees. For ripping I took one chain for my Stihl and re-ground the teeth to 10 degrees and it works great. The chain grinder has a scale on it for setting it to various angles.
There is a fair amount of confusion concerning "ripping" chain. What many call rip chain is actually skip-tooth chain (half or full skip) which has less cutters than "full comp) chain. Skip chain is used on bars 28" and up to reduce stress on motors, and is often used for rip cutting log sections because it's easier to pull fewer cutter through the long streamer shavings. It doesn't cut as fast as a full comp chain, and tends to produce a rougher cut because you have fewer teeth and rakers riding in the wood at a given moment. It should not be used in smaller saws because fewer teeth "in the cut" increases kickback and vibration and increases wear on the bar.
True rip milling chain is made in the Granberg style and is designed EXCLUSIVELY for Alaska and Granberg type chainsaw lumber mills. It has very high kickback force and should never be used in a handheld saw. Granberg chain is made by removing just the top plate on every other cutter in a full comp chain, but leaving the rest of the cutter intact and sharp.
What you may not be aware of is that hitting a big nail (especially an old one) will often damage a chain beyond meerly needing to be resharpened. It can weaken and even crack the cutter links in the chain such that they are prone to break during further use. Having your saw "throw" its chain during use is not a pleasant experience. If you hit a nail, you should change out the chain, and then carefully inspect the damaged links. Chains can be easily repaired by replacing damaged links, and you should consider this to maintain the strength of your chain.
If you're cutting a lot of "dirty" wood, you may want to consider carbide tipped chain. It is, however, very expensive, to the tune of $1.70 to $2 per cutter. You'll also be needing a diamond hone to sharpen it.
>Granburg does indeed have their own style of ripping chain with the tops of every other pair of cutters ground off. I also have several Oregon brand ripping chains and have found very litle difference in the speed of cut between the two styles of chain.
The biggest reason ripping chain is more prone to kick backs is because in adition to chainging the angle from 30 degrees to 10 degrees or less, the angle of hook is also changed. By increasing the hook to something close to 50 degrees you are presenting the cutting edge in a way that causes it to 'Bite' less and become more prone to bouncing. This is not an issue when the saw is clamped in a milling attchement, but I would not recomend using ripping chain for free hand cutting. I use two saws when milling one for actual milling and another with standard chain for trimming and preping the log.
>I modified my chains to a 27/57 compound grind. It leaves a bit more "meat" behind the beak, and I get better wear cutting hardwood. Big advantage to a bi-axial adjustable grinder.
