Glue for Sanding Mandrel
rthomas
>Problem: I have been attaching hook fabric to foambacked mandrel with various types of adhesives. When the sanding disc heats up it causes the adhesive to release the hook fabric. Does anyone know what glue will be heat tolerant?
TIA
Re: Glue for Sanding Mandrel
Chuck Engstrom
>You might try 3M 5200. I can't actually testify to its response to heat in this application but it is some very very tough stuff and does cure flexible, not hard like epoxy. The standard 5200 takes several days to cure but there's a fast cure version out also. If you can't find it at your local True Value. Lowe's, or HD, look for a marina.
Best--
Chuck Engstrom
Re: I have been using ....
Jamie Donaldson
>... Plumbing GOOP, one of several silicone adhesives available in handy tubes at Lowes.
Norm Smith in Nova Scotia
>I use flexible ca glue from Woodchuckers in Toronto Canada. I tried just about everything and found that this glue works best for me.
Dick Hines
Dick Hines
>For some years I have been using industrial grade H&L. We were useing it at work, wouldn't say where, it's 2" wide.
When the H&L comes off the sandie thing I run the pad on a piece of plywood to get all the hooks off. Then pull the backing off the H&L and stick it on the pad. Then trim to size. Only takes a few seconds and will stay on for quite some time. IF I don'tget heavy handed.
I think the H&L is a 3M product.
ted okolichany
>Bruce Hoover from the Sanding Glove uses and sells Goop Household glue. Works great, I been using in for the past 3 years..
Ted
Richard Allen
Richard Allen
>There are three solutions to your problem.
1. Dow Corning � SE 9152 HT silicone glue. 1-part reddish brown moisture cure RTV, fast tack free, good flow, high heat resistance.
2. Buy inexpensive mandrels. Industrial Abrasives sells 2" mandrels for $5 each.
3. Learn to sand without creating so much heat. Slower drill speed, slower lathe speed, sand with less pressure, start with lower grits, use more grits, spend more time inspecting and cleaning the workpiece between grits (lets the mandrel cool off).
I have tried all three methods.
3M Emblem Adhesive
Peter Teubel
>Available from any auto parts store. It used to affix emblems to cars and you know how tenacious they can hold. I've found that it holds up very well to heat on 3" sanding mandrels.
Allen Neighbors
>I've been using Weldwood Contact Cement. I've found that it will outlast anything else I've tried, including epoxy. All my little rollerblade wheel sanders are stuck with it, for well over 2 years now. I think if it releases, It'll be because I'm using too much pressure, or too much speed, either of which causes too much heat.
Re: 3M Emblem Adhesive
Bob Rogne
>Use less pressure and also less drill and lath speed.
Also, NEVER jump sanding grits.
Bob R WestMac Turnings
Rollerblade wheel sanders ???
Clem Wixted, Jonesboro, AR
>Allen,
Tell us a little about your rollerblade wheel sanders, please.
Clem
Me Too!
tek-Brunswick, Ohio
feathering disc adhesive
Robin Corell in Atascadero, CA
>feathering disc adhesive is what was used in body shops to glue sand paper to random orbit sanders before the PSA papers were available. it is a gummy adhesive that dosent realy actually dry which allows you to apply it once and then peel off a used paper and apply an new one without adding new adhesive. after a few times you have to add more.
I have not used it for what you are asking about but feathering disc adhesive has a very high tack and is not affected by heat. it has other draw backs, such as being messy and having such high tack that when paper is left on for a month it will only come off in itty bitty pieces.DAMHIKT
It used to be available from auto body supply shops but I have not bought any in years as a tube lasts a long time.
Robin Corell
