Re: Poll: Most difficult wood to dry...
Gary Evans Tallassee, TN
>You are correct, John.
All the factors you mention play a part in the tendency of a particular wood to split. When the stress induced by drying forces overcomes the strength of the bonds between the cells, the wood splits. The stresses are created when the wood cells in the surface layers dry below the fiber saturation point and start to shrink while the cells below them are somewhat wetter and still the original size. The wood tends to split along the radial surfaces because the rays are groups of horizontal cells compared to the vertical cells of the wood fibers. As we know from cabinet work, gluing crossgrains is not the strongest bond.
Regardless of the particular wood characteristics the most important factor to consider, and the only one which we can influence, is how much shock are we inducing in the wood. The amount of shock is directly related to the Moisture Content of the wood when it's cut and the Equilibrium Moisture Content rating of the space where we put it. If you take a piece of wood that is at 40 or 50% MC and put it into a space where the conditons will create an EMC of 7 or 8%, then you are going to have a tough time keeping the wood from cracking. On the other hand, if you can create conditions where the EMC is up around 20%, then you have a much better chance of a good result. AnchorSeal, paper bags, etc. are all methods to control the EMC conditions at the surface of the wood.
On the other hand, 20% EMC conditions are also excellent for growing fungus and mold, so you have to be careful about airflow. I'm not surprised that it is so difficult to give someone foolproof, step by step instructions on the best way to dry wood, particularly turning blanks.
It's lots of fun to take a bunch of laboriously prepared blanks to a symposium in an airconditioned space and watch them set there and check before you can get them sold because you didn't have any AnchorSeal left to put on them.
56 today and still learning about drying wood.
Gary
