Please help=== Refinish
Bill Hale / The Wood Spinner
>I know this is kind of a flat side question but finish is finish.
I gave my Daughter a large oak dinning room table and now she wants to stain it dark.
The problem is that it has received years of lemon oil wipping on a weekly bassis, well saturated.
What is your recomendation to do the refinish.
Thanks for help.
Bill
Re: Please help=== Refinish
Allen Neighbors
>Bill, If the piece has been wiped with Lemon Oil over the years, it's in fine shape... as far as the wood is concerned... and the Lemon Oil will not affect the staining in any way, as long as you use an oil-based stain.
The only thing that can affect the stain is a finish of some type that might prevent the stain's penetration. If you can find out what sort of finish it had, you will be able to find out how to reduce it in order to stain it.
I realize this is a little vague, but that's about all I know about it.
Dick Coers
>I agree that them lemon oil won't affect the refinish, just as long as there weren't anything else in the oil. Mainly any silicone, or maybe waxes. Was there any film clear coat on the table? It will have to come off before the new staining unless you want to use a lacquer toner, then clear coat on top of that. I don't like the lacquer toner because it's too close of a relative to paint. Finishers use the lacquer toner to even color, usually after staining. I recommend polyurethane for the top coat. Thin it a little if you don't want a thick build on the top.
>Thanks
The table had no finish when I got it.
I will tell her to just do it with oil stain.
Thanks again Bill
