>Got the Vicmarc mounted on a 2x10, with the motor hanging off the backside. Already changed the motor out. The one shown is a Marathon, and I replaced it with a General Electric/enclosed fan. The Marathon overheated...
I mounted a piece of 'soft-foot' rubber floor mat on the bottom. I turned a little bit with it on the tailgate. Stays put... no clamping necessary.
>Way to go Allen. When you take off the tailstock and banjo you have a very light unit to haul around. I like your idea everything is tied together. You may or may not need a spring back to your lathe board to reduce balance. Great idea, now you are ready to give demos to other turners. GT
>Thanks, Jorge. I showed it to a flatworker down at the fire station this afternoon, and one of the other guys asked me if I would show them how I turn at our next BBQ. Might get some more of them interested in turning. :)
>George, thanks for the comments. Got the ideas for most of it from TD.
What do you mean about the spring back to the lathe board?
You have to know what you're doing to give demos. :) I don't think I've got enough going for me yet to do demos. I just want to be able to turn a little at Craft Shows (that sort of demo might boost some sales) and when we're not showing our wares, I just want to be able to turn when we're on the road. :)
>Jamie, I used to be a proof reader at the newspaper... they're printed backwards. :) Just kidding.
The switch was one I had used before, and when I mounted it for this use, I turned it around backwards, because when I'm in a hurry, I can flip the switch in the first movement... going... instead of having to go past the switch and pull it back.
>Yep. And I tried it spinning at 950 rpm... grabbed the chuck and stopped the lathe, momentarily... just to see if a catch would make the belt slip... it will. That's good, for me.
I think I need to strengthen the hinge system, to keep the side pull from causing trouble with the little thin belt.
>This was the last VL100 that TD had on hand. He offered me a good deal on it, I said I'd take it, he shipped it from GA on Saturday, I received it in Texas, today at noon. That's what I call good service.
>Cool, Allen. I should take the extensions off and do that with my Jet mini. It's light enough that I could just plop it onto a workmate and start turning.
The Vic looks brand new, but I assume it wasn't since you had to replace the motor.
>Carole, thanks for the idea about the workmate... I hadn't thought of that. They fold up, won't take up much room. I've turned with it on the tailgate of my truck, and it works nice there, but there will be times that I won't be able to have my truck that close. A workmate would be ideal. :)
The little Vicmarc is new. It's the bench model. Comes without the motor, so you can rig it the way you want it, for travel, demos, etc. It's a lot lighter (even now with this 1/2 horse motor) than the VS model, which only has a 1/3 hp motor, and comes on an enclosed cast iron stand that houses the motor and inverter. The VS model costs twice as much as the bench model, also.
If you do shows, you might want to take your little Jet with you sometimes. I don't think you even have to turn on it, just have a work in progress on it and a few tools so you can do a short demo for those who are interested. At least, next week I'm going to find out if it will enhance sales. :)
>That's true. And now she's wondering if we're going to have enough room for all of our stock cases, because besides the lathe, I have to take along a box of finishing supplies, a roll of tools, a box of blanks, a grinder... :)
>Thanks... standard pulley... the Vicmarc pulleys fit a 5/8" motor shaft. Both of these motors had that size. :)
Speaking of pulleys... the one on the lathe, and the one for the motor was rough as a cob. Seems like they were covered with fine sand. Don't know if that's to make the belt grab better, or if it's designed to make it wear out quicker. Also, the belt is certainly a little skinny thing. About 7/16" wide X 1/8" thick, a grooved belt, like the new serpentine belts on cars. I'm afraid to leave the weight of the motor, as tension, on it, so I remove the belt from the motor when I quit turnin' on it for the day... I don't want it to break prematurely.
Has anyone had trouble with the small belts breaking?
>I have left the weight of my motor on mine for about 3 years now with no problem. I sometimes use a bungy cord for additional tension but I do not leave the bungy on when not in use. When it comes time to replace the belt I remember someone posting that you could buy a serpentine belt of a useable length and slit it into halves and get two for the price of one.
>TD, I just got back from all the parts stores in this town, and none of them have a serpentine belt that the grooves will fit the pulley. I took the pulley with me, to try to find an extra to have on hand on the trip.
All their belts, the vees were too blunt and wide to fit the pulley's grooves.
>Al, I wouldn't worry about a spare belt for this trip. If the pulleys are lined up that belt should last a long time. Greg Jensen is now handling Vicmarc I think. Email me if you need his email addy.
