Here it is...
steve antonucci
>In general, I use Ellsworth style boring bars. His cutters are CA glued into the holes at the end of the bar. As you can see, mine are held with a set screw. This bar is 5/8", and has two holes (one straight on and the other set at ~45 degrees. Both holes intersect at the set screw, which holds very well. In smaller bars, I CA glue the cutters.
This bar is the one that I used to hollow the bottom 1/3 of the vessel I posted last week. The mass and the thickness really minimize vibration. If you are cutting through a larger hole, you can hollow almost all of the vessel with the cutter in the straight positions. I have a few different bar sizes, and a few angles that the cutters are set, but this is all that I use.
Each bar costs about $3-5 to make, and most of them I make in 10 minutes or less. If you undercut a vessel top, you'll need a bent bar, but it won't need to be real thick unless you make really big vessels.
Steven
