Follow up on silver soldering post
Don henthorn
>Tried all the suggestions from a couple of days ago and even ground the two surfaces to make sure they were clean. No luck. This is crazy; I used to do this with no problem. Any way I used Mark M's suggestion and got the hole drilled in the end of the 3/8" rod and used the CA glue and it worked. One tool down and the hook tool to go. The next one is 5/16" drill rod which is going to be more of a challenge to drill. I got to keep on trucking.(G)
