Re: Curosity about your dust collection system
Fog Tanner
>I have a 2hp Onedia cyclone system which moves a lot of air. I don't know what the airflow of you Griz is, but assuming its close to the Oneida - horsepower doesn't always mean airflow - its all in the impeller. If it is, your ducting is too small. Mine starts at 7", then into 6", and the majority is 5", with one short run of 4". You have to measure the pipe size against the airflow. Too small and you can increase the flow, but the air is moving too fast and won't pick up enough dust. Too large and the air is not moving fast enough to carry the dust all the way to the unit and it can stack up in the column. The right size should carry the dust from the pick up all the way to the collector. That is why I have the various sizes, to maintain the correct airflow as the ditance changes. I bought the unit from Onedia, so they figured the size of the runs for me.
I have very little flex, only what is necessary to hook the the various tools. One foot of flex is about 3 feet of duct in air drag, same with elbows. The short radius are probably worse. All the elbows are large radius, which you can't get in PVC from the box stores. I use 45 degree pickups where possible. The Wye's that connect into the line are 45's, another thing you really want to try and do. I used all metal Snap-loc, which was easier to run than PVC, just not as cheap. The options for connectors is also greater. Everything is sealed with metalic silcon caulk so I don't have any leaks.
The best pickup I found for the lathe, was one of those large rectanular "funnels" that are sold for use on radial arm saws. It has a 4" pickup in the back. I built an open "box", where the funnel is setting at about a 35 degree angle. This sits on a table behind the lathe and works great for getting most of the dust. I have two blast gates and two pickups for the lathe. I just haven't gotten around to making a pickup for the front of the lathe. I haven't found one I like, so I am going to make one out of fiberglass and resin. But, that entails making a plug and mold and I'll wait till winter for that.
All that is good for about 90% of the dust, for the other 10% I use an Airstream. I wear that the whole time I am turning, even coring - thats where the "helmet" part comes in. And generally, when I am through turning I leave the shop. There will still be some dust in the air, the submicron particles. Which also happen to be the ones that do the damage. So, you really don't want to hang around too long without a respirator on.
Good luck on keeping your lungs functioning, you have a great start at it and are thinking ahead.
