arboteck mini carver,
Eduardo Sarmiento
Eduardo Sarmiento
>hi there glad to be back hope to get some comments about the mini grider ,tips etc
Re: arboteck mini carver,
Dinyar Chavda
>Eduardo:
I don't know if you've bought it, but if I had to do it again, I'd probably buy the Proxxon, as it seems to be easier to get into tight places.
There is a video by Arbotech on the use of the grinder---it's worth borrowing from someone if they have it.
It is pretty easy to operate, and to get a fairly smooth surface with a little practice, and is nowhere near as scary as the big Arbotech.
I haven't used it, but Graeme Priddle said that the sanders that come with it are pretty useless, as the tool spins too fast.
Hope that helps
D
>Eduardo I'm still very new at using mine although I've used the larger chainsaw type grinders for years. I like it a lot although it is a little large for delicate work. I stayed away from the proxxon because I saw too many complaints on the net about them dying. I did try out the proxxon at the Louisville symposium and it seemed like a nice tool to me.
I've had a lot of success with the 3/1/2 inch grinders and the larger cutter so it seemed logical to try the mini grinder. Someone just did a review of this tool somewhere on one of the newsgroups and the most common problem was the drive belts breaking.
I look forward to trying mine out again but I've just been too busy lately.
I have both of these
Keith Newton
>and I can't recommend the proxxon for using the arbortec cutters on. I thought it would be handy because of having the narrow neck, and might get into small spaces etc. but it is too underpowered. It is awfully easy to turn on the switch by accident also, which makes it more dangerous than a tool like that should be.
On the other-hand, I converted mine to a dedicated little right angle grinder, and I love it for that purpose. Unlike what you said about Grame. I took the little guard off of the end, which was in the way. The little plastic backer disk that comes with a round sanding disk hot-glued on it, I tore off the abrasive disk that comes on it, then scuffed the face with coarse paper, then sprayed it with high-strength contact cement.
This makes a better surface to hold the little disk that I punch out of the larger 6" disk that I keep on-hand for my random-orbit sander. One of those will yield a dozen small disk for this tool, so they are very economical, and cut fast and fine. They are also quick and easy to change as long as you peel the worn out one while the glue is still warm from recent contact friction.
If you buy the standard arbortec, I find that mine feels better in the hand, and is easier on my other joints, also is easier to control with the arm on the end mounted at about 45� off to the right as the tool is facing away from me, rather than straight off of the end like is shown in the ads. I know that if you buy it with already mounted on the grinder motor, that it will have three screws that makes it appear to not be adjustable, but I have been using mine on another brand of grinder that the holes wouldn't align with, and it is just mounted with the clasping screw around the bearing housing on the grinder.
I hope I have given you some useful information. K
Re: I have both of these
Ralph Watts
>Like Keith I have both of these tools. My Proxxon was sent for repar two times. The second time they changed the head out with a new design and it is far more reliable. However, the switch is a safety issue but I wouldn't trade this tool for anything. I find it most useful for carving fairly small stuff, e.g. legs on a bowl.
The larger arbortech cutter is used for big stuff and removes wood faster than any other tool on the market. The nice thing about these cutters is that they are not agressive and very controlable.
Don't buy the Proxxon with all extras--the tool with an arbortech cutter is all you need to carve.
Regards, Ralph
Eduardo Sarmiento
Eduardo Sarmiento
>Thanks a lot the answers are on the ball, ill make up my mind and buy the arbotech complete,plus de carbide blade my grinder is chinese and no collar ,but for 20 us you can be fussy about it no?
work great and i can sand the pieces real quick,of course the trick is to let it cool,after few minutes and it will run forever
thank for the info,great help
